Go to Post FIRST for me is getting to opportunity to learn from the smartest people I know, the mentors. - faust1706 [more]
Unread 12-02-2013, 14:32
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: 6wd bouncing when turning
Originally Posted by lemiant View Post
We have a problem. Our robot rocks wildly when turning at high speeds.
This year we designed our robot to have a similar configuration to a kitbot. We are 26" long by 23.5" wide using 6 wheel drive and 4" Andymark white traction wheels driven via belts off a pair of vexpro ball shifters. The center wheels have 1/8 of an inch of drop, enough that our robot can rock slightly when placed on the carpet. Our weight is distributed towards the back of the robot so that the back four wheels are usually touching the ground. Based on everything I know about drivetrains our wheelbase shouldn't have major scrub problems, but obviously it does. Are there any simple fixes we may have overlooked?
Thanks for your help,
- Alex
As said above stiffness is important in a drop wheel chassis. You could also do omins in the corners as a last ditch fix.
And always on CD a photo would help.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 12-02-2013, 14:59
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
1/4 inch lexan will do the trick, however 1/4 plywood will be more that adequate to keep the frame stiff. We did that last year in our sheetmetal chassis and it worked great! If you have access to a waterjet/plasmacutter/laser you may want to consider a pocketted 1/8 (or thinner) aluminum bellypan....keep time in mind as it is already week 6.
Good luck from team 1325!
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 12-02-2013, 18:06
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
Stiffness will be a factor, but as you mentioned in the original post, the back two wheels are the ones in contact with the floor due to CG placement. This will inherently cause scrubbing because a four wheeled drive base cannot turn without a component of movement perpendicular to that of the wheels rotation. The point of the 2 lowered center wheels is to keep weight off of the four wheels on the outside corners of the drive base (the ones that scrub) but since the rear four wheels are in contact, you essentially created a four wheeled drive base within your six wheeled base. This means the scrubbing is unavoidable, you will only be able to reduce the severity of the bumpy turns by making your frame stiffer.
Unread 12-02-2013, 20:43
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
We use flat twin-wall corrugated aluminum for our baseplate every year. It has worked well for us so far although it might be a little bit heavier than some other options.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 13-02-2013, 00:52
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
The length to width ratio of either set of four wheels however is quite acceptable. We built a 4 wheel drivetrain with a smaller ratio last year without any scrub problems.
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 13-02-2013, 07:01
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Can't say that I've personally tried this, but one stiffening idea that's been bouncing around my team for a while is using tensioned wires along each chassis bar.
Unread 13-02-2013, 07:04
Olin class of 2019
The point of a six wheel drive is in fact to create a smaller four wheel drive turning base while keeping a large wheelbase for stability. This is a common misconception that I've seen - that 6 wheel drive robots turn on two wheels.
They don't - they turn on four, but on a much shorter turning wheelbase than their stable wheelbase. There's a nice whitepage somewhere which describes this.
Unread 13-02-2013, 07:24
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
We had a similar problem with our 2011 bot! We had a 2 wheel drive with 4 cims to power it and the back wheels just skidded on the floor. What we did is we ended up putting omni wheels on so they slide across the floor instead of jump. I dont know if that is an option, but I would seriously consider it
