Re: Battery
I agree with everything that was already stated.
I suggest that you go to Goodwill or some other thrift shop and buy some free weights. They always seem to have a few random pieces around. Used sporting good shops also sometimes sell extra unmatched weights individually for a modest price. The advantage of using weight lifting weights is that if you buy them in small weight units the weight will be easily adjustable. They are also more compact, and they come with a convenient mounting hole. |
Re: Battery
Re: Battery
I remember seeing a robot with an arbor press attached to it as ballast..
Re: Battery
I was on MOEbile pit and the team's robot was so light their wheels has almost no traction. I used their pit vice as the clamp to attach the press to the frame for even more weight ![]() |
Re: Battery
Aj,
One and only one battery is permitted on the robot, see R34. Other battery types are allowed if and only if they are part of a COTS computing device or enclosed camera. Weight may be added provided a few items are met. Free weights, steel plate, vises, etc. must be firmly attached to the robot. Ty-wraps, tape, wire, twine or rope, etc. do not meet the "firmly attached" definition. Attachments can be appropriate hardware, welding, etc. As to lead, it must be entirely painted or sealed prior to attending an event. It may not be machined at the event. As to other types of weight, notably shot, sand, liquid, etc., this must be enclosed in a container that will not spill or crack open with the forces normally encountered on the field. More than once, teams have added these items and we spent considerable time cleaning the residue from the field. Considering the nature of the game, if you climb, it seems that additional weight would work against you. |
Re: Battery
Of course, there are safety issues to be addressed, and I think there are better ways of adding ballast to a robot. But, I can't resist a good debate. I'm just saying I don't think the battery as ballast is inherently illegal. |
#7
Re: Battery
Re: Battery
Cal,
Please note that all references to the battery in the robot rules is in the singular, meaning one. This has been answered in the Q&A for several years in this fashion. However, I do not remember seeing that question asked this year. If there is still some confusion, someone should ask to remove all doubt. |
#9
Re: Battery
I would say that having an extra part of acid and lead is by definition unsafe. One is dangerous enough.
