Go to Post "Why even bother building a robot if we're not gonna win?". The answer? To learn and grow. - MrBydlon [more]
Unread 23-01-2003, 06:04
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Originally posted by Mike Rozar
How about using a simple multi-position rotary switch on the robot?
Safer than combinations of toggle switches, etc......
One of the problems I foresee is that for the digital inputs on the RC, we're warned not to apply any voltage to the switch pins, and to just ground them to return 1. "All additional electronics must draw power from a 20A circuit breaker," (The_Robot.pdf, page 13, emphasis added by me).
I'm not sure if this means that just attaching a few switches to the digital input pins of the RC is illegal, but unless it's already been clarified, and I just haven't seen it, I'm fairly certain that this rule could become very important.
I might just be delusional, at this time of night. Don't mind me if I just sound dumb. It's probably normal...
Originally posted by gwross
Are you sure the e-stop resets the robot? If not, then the initialization section will not get rerun.
I believe he's referring to the Robot Reset button on the OI, not the E-Stop button at the player station.
I'm fairly certain that he's correct in his assessment of the situation, and what he's saying does make sense to me. However convoluted a method it is, it probably works.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
