Go to Post ...remember, this is coming from someone that spent the better part of an afternoon playing with an omniwheel--not assembling, not disassembling, just playing. - Billfred [more]
Unread 08-02-2013, 20:12
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Arrowhead is an unknown quantity at this point
Deadzone Programming
I looked around a bit but couldn't find any resources on this for c++
How do you program in a deadzone for a attack 3 joystick?
I wrote this code but it doesn't seem to be working.
	void driving(){
		double y;           //variable for forward/backward movement
		double x;           //variable for side to side movement
		double turn;        //variable for turning movement
		if(driverStick.GetY()>0.3||driverStick.GetY()<-0.3){
			y=driverStick.GetY();
		if(driverStick.GetX()>0.3||driverStick.GetX()<-0.3){
			x=driverStick.GetX();
		if(driverStick2.GetX()>0.3||driverStick2.GetX()<-0.3){
			turn=driverStick2.GetX();
Unread 08-02-2013, 20:20
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Re: Deadzone Programming
Try this, you need to set default values. Also I just cleaned it up a bit.
void driving(){
	double y = 0;           //variable for forward/backward movement
	double x = 0;           //variable for side to side movement
	double turn = 0;        //variable for turning movement
	double deadzone = 0.3;	//variable for amount of deadzone
	if(driverStick.GetY() > deadzone || driverStick.GetY() < -deadzone) {
		y = driverStick.GetY();
	if(driverStick.GetX() > deadzone || driverStick.GetX() < -deadzone) {
		x = driverStick.GetX();
	if(driverStick2.GetX() > deadzone || driverStick2.GetX() < -deadzone){
		turn = driverStick2.GetX();
Unread 08-02-2013, 20:22
AKA: Daniel Brown
Ok, thanks, I'll try that at practice on monday.
Also, how does setting default values for those variables change it?
Unread 08-02-2013, 20:24
DjMaddius's Avatar
AKA: Matt Smith
Well, if you don't and you try to use it later after the if statement failing the value is set to null and you'll get an error.
Unread 09-02-2013, 09:46
kylelanman's Avatar
kylelanman kylelanman is online now
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
We've found the following to work great for dead zones. The main advantage is you can still generate values between 0 and .3. With the previously posted solution once you get out of the dead zone you're instantly outputting .3 or 30%. If you notice we have a lot of 127s in the middle of the array. Those provide the dead zone but we shift everything else over so that once your out of the dead zone it doesn't go straight to .3.
This was written on the old control system. Technically the cRio has enough power to run the equation we are using to generate the array. We've just never taken the time to switch it over.
const char inputShape[255] = {0,1,3,4,5,6,7,9,10,11,12,13,15,16,17,18,19,21,22,23,24,25,27,28,29,30,31,
	        33,34,35,36,37,38,40,41,42,43,44,46,47,48,49,50,52,53,54,55,56,58,59,60,61,62,
	        64,65,66,67,68,70,71,72,73,74,76,77,78,79,80,82,83,84,85,86,88,89,90,91,92,94,
	        95,96,97,98,100,101,102,103,104,106,107,108,109,110,112,113,114,115,116,117,
	        118,119,120,121,121,122,123,123,124,124,125,125,125,126,126,126,126,126,127,
	        127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,
	        128,128,128,128,128,129,129,129,130,130,131,131,132,133,133,134,135,136,
	        137,138,139,140,141,142,144,145,146,147,148,150,151,152,153,154,156,157,158,
	        159,160,162,163,164,165,166,168,169,170,171,172,174,175,176,177,178,180,181,
	        182,183,184,186,187,188,189,190,192,193,194,195,196,198,199,200,201,202,204,
	        205,206,207,208,210,211,212,213,214,216,217,218,219,220,221,223,224,225,226,
	        227,229,230,231,232,233,235,236,237,238,239,241,242,243,244,245,247,248,249,
	        250,251,253,254,255};
float InputShape(float userValue)
		int iUserValue;
		iUserValue = (int)(userValue * 127);
		iUserValue += 127;
		iUserValue = inputShape[iUserValue];
		userValue = iUserValue - 127;
		userValue /= 127;
		return userValue;
--SNIP--
ly = InputShape(stick->GetRawAxis(2));
ry = InputShape(stick->GetRawAxis(5));
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 11-02-2013, 11:12
AKA: Daniel Brown
		int iUserValue;
		iUserValue += 127;
		userValue /= 127;
		return userValue;
--SNIP--
Quick question abotu the code, where does the variable userValue come from?
Unread 11-02-2013, 11:35
It comes from whatever line calls the InputShape() function.
Unread 11-02-2013, 13:27
AKA: Daniel Brown
Gah, wasnt paying attention lol
Unread 12-02-2013, 13:51
David++ David++ is offline
Rookie Year: 1900
David++ is an unknown quantity at this point
void driving(){
Instead of checking for both the positive and negative deadzone, you can just take the absolute value. In addition, you can reduce the number of function calls to GetX() and GetY() by assuming the value is valid and handling the exceptional situations.
#include <math.h>
void driving() {
    double y = driverStick.GetY();
    double x = driverStick.GetX();
    double turn = driverStick2.GetX();
    if(fabs(y) < deadzone)
        y = 0;
    if(fabs(x) < deadzone)
        x = 0;
    if(fabs(turn) < deadzone)
        turn = 0;
Or, if you prefer the compact Arithmetic If operator:
#include <math.h>
void driving() {
    y = ((fabs(y) < deadzone) ? (0) : (y));
    x = ((fabs(x) < deadzone) ? (0) : (x));
    turn = ((fabs(turn) < deadzone) ? (0) : (turn));
Unread 12-02-2013, 15:25
AKA: Daniel Brown
Thanks! Also, did you mean abs() instead of fabs()?
Unread 12-02-2013, 17:41
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
abs() takes an int and returns an int. fabs() takes a float and returns a float.
Since Joystick::GetX() and GetY() return floats, he did mean fabs().
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
Unread 12-02-2013, 18:01
AKA: Daniel Brown
Ah, thanks for the correction.
