Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Unread 02-12-2013, 05:40 PM
TachyonicTalker TachyonicTalker is offline
FRC #4013
TachyonicTalker has much to be proud ofTachyonicTalker has much to be proud ofTachyonicTalker has much to be proud ofTachyonicTalker has much to be proud ofTachyonicTalker has much to be proud ofTachyonicTalker has much to be proud ofTachyonicTalker has much to be proud ofTachyonicTalker has much to be proud of
Line 41 Error Downloading Java Code
First of all, hello!
At the beginning of the season our team got the newest model of the Classmate PC. With our old classmate and the old cRio image (v27) we would be able to download our code just fine and run it on the driver station without issue, but with our new classmate and v43 of the cRio, we hit an error while compiling every time. I think we are missing a bit of essential software on our classmate, but we have completely wiped it and re-installed everything (in case of an incorrect download) and can't find any software online that we don't have. Any suggestions of what the issue might be would be greatly appreciated.
ant -f C:\\Users\\Developer\\Desktop\\Drive2013V3 deploy run
clean:
Deleting directory C:\Users\Developer\Desktop\Drive2013V3\build
Created dir: C:\Users\Developer\Desktop\Drive2013V3\build
Created dir: C:\Users\Developer\Desktop\Drive2013V3\build\classes
[crio-compile] ./src, C:/Users/Developer/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/Developer/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/Developer/sunspotfrcsdk\lib\squawk.jar -> ./build/classes
Compiling 1 source file to C:\Users\Developer\Desktop\Drive2013V3\build\classes
compile:
preverify:
Created dir: C:\Users\Developer\Desktop\Drive2013V3\build\preverify
Created dir: C:\Users\Developer\Desktop\Drive2013V3\build\preverify.raw.util
[crio-preverify] ./build/classes, , C:/Users/Developer/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/Developer/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/Developer/sunspotfrcsdk\lib\squawk.jar -> ./build/preverify
Expanding: C:\Users\Developer\sunspotfrcsdk\lib\wpilibj.jar into C:\Users\Developer\Desktop\Drive2013V3\build\preverify
Expanding: C:\Users\Developer\sunspotfrcsdk\lib\networktables-crio.jar into C:\Users\Developer\Desktop\Drive2013V3\build\preverify
jar:
[crio-jar] ./build/preverify, ./resources -> ./build/app.jar
Building jar: C:\Users\Developer\Desktop\Drive2013V3\build\app.jar
suite:
Created dir: C:\Users\Developer\Desktop\Drive2013V3\build\suite
[crio-suite] ./build/app.jar -> ./build/suite/image
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 378 classes and generated 4 files.
Expanding: C:\Users\Developer\Desktop\Drive2013V3\build\app.jar into C:\Users\Developer\Desktop\Drive2013V3\build\suite
Moving 1 file to C:\Users\Developer\Desktop\Drive2013V3\build\suite
Deleting: C:\Users\Developer\Desktop\Drive2013V3\image.suite.api
deploy:
[crio-configure] Configuration files not included in this version of the sdk
[crio-configure] Checking that crio is configured for Java
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) Client VM 23.6-b04
Target IP: 10.40.13.2
Network interfaces on host:
    Realtek PCIe FE Family Controller:  address: 10.40.13.5 netmask: 255.255.255.0 <--- on robot's subnet
Connecting FTP @10.40.13.2
C:\Users\Developer\sunspotfrcsdk\build.xml:78: The following error occurred while executing this line:
C:\Users\Developer\sunspotfrcsdk\ant\configure.xml:41:
java.net.SocketException: Software caused connection abort: socket write error
	at java.net.SocketOutputStream.socketWrite0(Native Method)
	at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:109)
	at java.net.SocketOutputStream.write(SocketOutputStream.java:153)
	at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)
	at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:291)
	at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:295)
	at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
	at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
	at java.io.BufferedWriter.flush(BufferedWriter.java:254)
	at org.apache.commons.net.ftp.FTP.__send(FTP.java:496)
	at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:470)
	at org.apache.commons.net.ftp.FTP.sendCommand(FTP.java:547)
	at org.apache.commons.net.ftp.FTP.port(FTP.java:872)
	at org.apache.commons.net.ftp.FTPClient._openDataConnection_(FTPClient.java:667)
	at org.apache.commons.net.ftp.FTPClient.retrieveFile(FTPClient.java:1595)
	at com.sun.spot.sdk.tool.ftp.UpgradeTask.checkVersion(Unknown Source)
	at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Unknown Source)
	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
	at sun.reflect.GeneratedMethodAccessor77.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
	at org.apache.tools.ant.Task.perform(Task.java:348)
	at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:68)
	at net.sf.antcontrib.logic.Switch$Case.execute(Switch.java:171)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at net.sf.antcontrib.logic.Switch.execute(Switch.java:138)
	at org.apache.tools.ant.taskdefs.MacroInstance.execute(MacroInstance.java:398)
	at org.apache.tools.ant.Target.execute(Target.java:392)
	at org.apache.tools.ant.Target.performTasks(Target.java:413)
	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
	at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
	at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
	at org.apache.tools.ant.module.bridge.impl.BridgeImpl.run(BridgeImpl.java:283)
	at org.apache.tools.ant.module.run.TargetExecutor.run(TargetExecutor.java:541)
	at org.netbeans.core.execution.RunClassThread.run(RunClassThread.java:153)
BUILD FAILED (total time: 34 seconds)
Unread 02-12-2013, 05:58 PM
FRC #4013
Re: Line 41 Error Downloading Java Code
Wait, found the problem, it was the firewall.
Woops...
Well at least problem solved.
