Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
Unread 12-02-2013, 18:55
SuperMario SuperMario is offline
FRC #3692
SuperMario is an unknown quantity at this point
cRIO update?
We just updated the cRIO to the 2013 image and now netbeans throws this error and we have no idea what to do, can anyone help?
Expected version "Java;" for Language but got "LabVIEW;". Go to http://first.wpi.edu/FRC/frcjava.html to get latest software update
BUILD FAILED (total time: 28 seconds)
Unread 12-02-2013, 19:07
Re: cRIO update?
It means that when you re-imaged the cRIO, you accidentally chose LabVIEW instead of Java in the development environment selection.
Unread 12-02-2013, 19:27
FRC #3692
Re: cRIO update?
but doesn't it say Java is expected
Unread 12-02-2013, 20:14
AKA: Brad
#0190 ( Gompei and the Herd)
Re: cRIO update?
This message that you are seeing, "Expected version "Java;" for Language but got "LabVIEW;"" is saying that the Java FTP code tried to verify that Java was the language on the cRIO, but found LabVIEW instead. So go ahead and run the cRIO Imaging tool and just change the language to Java. No need to reformat.
Brad
Brad Miller
Robotics Resource Center
