Go to Post Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 12-02-2013, 20:23
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Jaguar running Mini CIM flashes red?
Hello!
We have a Black Jaguar running a Mini CIM motor. When we order it to give 100% power forward, we can see the motor is trying to move, but doesn't. After a few seconds (around 3) the Jaguar stops delivering power, flashes red for a while and then goes back to solid yellow.
What can cause this behaviour? When the motor is connected straight to a battery it spins quite fast...
Thanks!
Unread 12-02-2013, 20:34
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Jaguar running Mini CIM flashes red?
Flashing Red is the jaguar's fault code. If you are pulling to much current this can happen.
From this manual http://www.ti.com/lit/ug/spmu131a/spmu131a.pdf
A slow flashing Red LED indicates that the MDL-BDC24 detected one of the following fault
conditions:
„ Power supply under-voltage
„ Over temperature
„ Over current
„ Limit switch activated in the current direction of motion
When a fault condition occurs, the motor shuts down and the LED indicates a fault state during the
fault condition and for 3 seconds after the fault cause is cleared (except for the limit switch fault, which is cleared instantly). A slow flashing Yellow LED indicates that the MDL-BDC24 is not
receiving a valid control signal.
Unread 12-02-2013, 20:43
Itamar's Avatar
How can I confirm that the motor is indeed pulling too much current?
Unread 12-02-2013, 22:52
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
By measuring your current with a clamp-on amp meter.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 12-02-2013, 22:56
Engineering Coach
If you don't have a clamp-on amp meter, you could try using a victor/talon in place of the Jaguar and if the breaker on the PD board snaps than you know.
Also try to unload the motor (disconnect it from what ever it's driving, your climbing device or what ever it's attached too) and then power it. The Jaguar will probably work fine if the motor is allowed to free spin. If it still faults, make sure you can spin the motor easily by hand. A recent post showed a brand new motor that had it's internals messed up so it would stall.
Unread 13-02-2013, 01:01
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
Are you using CAN or PWM? If you are using CAN you can query the jaguar to find out how much current is it drawing as well as which fault condition it is.
Also if you use a clamp on amp meter be sure it can measure DC, as most do not.
Does the motor hum when the jaguar is sending power?
Have you tried swapping out the jaguar?
My guess is that something mechanical is binding and making it hard for the motor to spin.
2017 Shenzhen, China Regional CSA
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2007 - 2008 Team 41 Lead Programmer, Electrical
2005 - 2008 Team 41 Member
2008 NYC Regional Winner
Unread 13-02-2013, 08:59
Itamar's Avatar
There was a misunderstanding, it turns out the motor did not move even when connected straight to a battery. It was a mechanic fault that has been fixed. Thank you all!
