Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Unread 12-02-2013, 21:14
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
A bumper design question.
Hi,
I have been looking to mount the rear bumpers on the bot. However, we have a series of bolts (two) that extend 3/4 of an in beyond the frame. As of now, I was considering drilling corresponding holes in the bumper backer, allowing the bumper to sit flush against the frame (with the bolt ends inside the bumper).
Would this be legal? I searched through Q/A as well as the rules and couldn't find anything relating to the topic. I do feel, however, that I might not get a response from Q/A (design review rather than a rule clarification).
I can answer clarifying questions, provide pics, etc.
Thanks
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 12-02-2013, 21:24
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
Re: A bumper design question.
Drill the clearance holes in the plywood so it sits flush against the frame. If questioned just tell the inspector I said it was ok. I can't quote exact ruling but we've used the method on teams for years. Just be sure the holes don't compromise rigidity or other rules.
Unread 12-02-2013, 21:28
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
That isn't how it works.
Me: But Mr. inspector sir, some person on Chief Delphi said it was ok, pass me!
Inspector: Incorrect
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 12-02-2013, 21:39
"Pocketing" the bumper backing to accommodate minor protrusions beyond the frame perimeter is okay. However, <R02> says such protrusions cannot be more than 1/4 inch. Your bolt heads go beyond that, so they'll end up defining the perimeter.
If you can't move the bolts, I think a good option at this point is to add a 1/2"-thick "shim" to the side of the frame where those bolt heads are. It'll add an inch to your perimeter measurement, though.
Unread 12-02-2013, 21:42
Build Lead
Yeah, I figured that would be the case. I designed the robot to fit within 112 in frame perimeter rule with those bolts, so its not a problem to add the shim.
Thanks.
