Go to Post Liberal arts majors learning more STEM concepts along with STEM majors learning more 'liberal arts' is a good idea. - ebarker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2013, 21:38
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: Eyebolt help
I would note, however, that your Eyebolts really should be capable of supporting the robot should something go wrong while belaying. Nice sized steel eyebolts should have no problem - just watch where you attach them. Our team is bolting them through our frame, possibly with suspension cable reinforcement.
Unread 12-02-2013, 23:24
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
Re: Eyebolt help
The mcmaster bolts are a cast eyebolt that supports 500 lbs if I remember correctly.
Most of the ones I found locally were formed by bending the hook to make the eyelets and only support 75 lbs. Be sure to get the cast type. The local Fastenal did have the correct kind. And McMaster ships very quickly. I didn't check the big box stores. Anyone have luck finding them there?
