Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
Unread 12-02-2013, 22:26
IDKnow IDKnow is offline
FRC #1671
IDKnow is an unknown quantity at this point
Re: Network Tables
Could I get a basic primer code in java for the client and cpp for the robot to start from?
Unread 27-02-2013, 15:47
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
twiggzee is an unknown quantity at this point
Re: Network Tables
I am having the same problem. I started with Daisy's vision code from last year and have modified it to fit our needs. The following line
Robot.getTable().putNumber("azimuth", azimuth);
prints a value to the SmartDashboard but I cannot retrieve the value from the robot side code:
SmartDashboard.getNumber("azimuth");
but i get an error saying that there is no such key. I played with this alot until I gave up and tried the NetworkTables method here but i can't seem to get it to work either.
With the following lines, I lose camera feed on the SmartDashboard:
NetworkTable.setClientMode();
NetworkTable.setIPAddress("10.35.2.2");
NetworkTable table = NetworkTable.getTable("visiondata");
table.putNumber("azimuth", azimuth);
When I comment out the first 2 of those 3, I get my camera stream back but still no data output.
Any ideas??
Wendy
Team 3502
