Go to Post Careful what words you use here; we take them literally. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2013, 20:48
Jester-3734 Jester-3734 is offline
FRC #3734
Jester-3734 is an unknown quantity at this point
Eyebolt help
Hi Everyone,
I need some help finding the eye-bolts that are required to be attached to the frame for belaying purposes. Any help would be much appreciated!
Thanks, Jester
Unread 12-02-2013, 20:57
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Re: Eyebolt help
Your local hardware store should sell them. Just make sure that the inner diameter of the eyebolts are at least 3/4 inches in diameter.
Unread 12-02-2013, 21:05
FRC #3734
Re: Eyebolt help
There isnt a specific load requirement?
Unread 12-02-2013, 21:15
Re: Eyebolt help
These are the only rules for the robot:
R10
Teams must supply at least two (2) attachment points for the belaying device (see Section 2.2.5) to mount to their ROBOTS. Attachment points must be:
easily accessible after the ROBOT has CLIMBED the PYRAMID,
on opposite sides of the ROBOT,
located near the ROBOT’S balance point, and
made from exposed structural members that will allow a rope to be wrapped around it or two eyelets (McMaster PN3014T45 or similar) mounted to the frame. Opening of the eyelets must be at least ¾ in. in diameter.
Unread 12-02-2013, 21:38
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: Eyebolt help
I would note, however, that your Eyebolts really should be capable of supporting the robot should something go wrong while belaying. Nice sized steel eyebolts should have no problem - just watch where you attach them. Our team is bolting them through our frame, possibly with suspension cable reinforcement.
Unread 12-02-2013, 23:24
annie1939's Avatar
annie1939 annie1939 is offline
AKA: Ann Fairburn
FRC #4388 (Ridgebotics)
annie1939 has a spectacular aura aboutannie1939 has a spectacular aura aboutannie1939 has a spectacular aura about
Re: Eyebolt help
The mcmaster bolts are a cast eyebolt that supports 500 lbs if I remember correctly.
Most of the ones I found locally were formed by bending the hook to make the eyelets and only support 75 lbs. Be sure to get the cast type. The local Fastenal did have the correct kind. And McMaster ships very quickly. I didn't check the big box stores. Anyone have luck finding them there?
Unread 12-02-2013, 23:41
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
but thats at least 150lbs with the set of 2 however thats without dynamic loads...
Unread 14-02-2013, 00:22
annie1939's Avatar
AKA: Ann Fairburn
Re: Eyebolt help
That is true, however the specified part is rated at 500 lbs. To me, 75 lbs is not similar to 500. And when you add up to 20 lbs of bumpers and a battery, you are approaching 150 lbs. There is nothing worse than driving around a strange city looking for an open Graingers so that you can pass an inspection. However, you can avoid the whole eyelets thing by having structural members on each side of the robot near the balance point that they can wrap a rope around as per the rules.
Unread 14-02-2013, 07:44
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: Eyebolt help
R10
I'm just going to leave it there
http://www.mcmaster.com/#catalog/119/1487/=lh2gyy
Your load requirement is your robot weight. Preferably, one eyelet should be able to hold your robot with a safety factor. The dynamic loading on these bolts is not going to vary much from the static load since the robot is being moved by team members. The belayer will be slacking the line to keep the line taut.
Unread 14-02-2013, 08:05
Re: Eyebolt help
Everyone,
The eyebolts shown in the rule are suggested parts not the required parts. You need attachment points of any type that meet the requirement.
Unread 19-02-2013, 12:39
benjie.roth benjie.roth is offline
FRC #2877
benjie.roth is an unknown quantity at this point
Re: Eyebolt help
Our robot is getting to have about an inch in the second level but most of it will only climb to the first level. Do we still need the belaying hooks?
Unread 19-02-2013, 12:45
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
Re: Eyebolt help
Yes, you will still need them. All robots, regardless of climbing ability, will need the hooks according to <R10>.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 19-02-2013, 22:26
shawnliner shawnliner is offline
FRC #3753 (BulahBots)
shawnliner is an unknown quantity at this point
Re: Eyebolt help
Q&A confirms that ALL robots need attachment points.
Q. R10 If you don't plan on climbing above zone 1, do you still need to provide fasteners/mounting points for the belay system on your robot? If you don't will this violate R10?
2013-01-16 by FRC0133
A. Yes, [R10] requires all ROBOTS to have attachment points for the belay system.
https://frc-qa.usfirst.org/Question/194/questionlink
Shawn Liner
Coach
Team 3753
When I learn, I win. If I can win too, that's gravy.
