Go to Post Brains and hard work aren't necessarily about age or grade. - Redhead Jokes [more]
Unread 13-02-2013, 00:52
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: 6wd bouncing when turning
Originally Posted by Bstep View Post
Stiffness will be a factor, but as you mentioned in the original post, the back two wheels are the ones in contact with the floor due to CG placement. This will inherently cause scrubbing because a four wheeled drive base cannot turn without a component of movement perpendicular to that of the wheels rotation. The point of the 2 lowered center wheels is to keep weight off of the four wheels on the outside corners of the drive base (the ones that scrub) but since the rear four wheels are in contact, you essentially created a four wheeled drive base within your six wheeled base. This means the scrubbing is unavoidable, you will only be able to reduce the severity of the bumpy turns by making your frame stiffer.
The length to width ratio of either set of four wheels however is quite acceptable. We built a 4 wheel drivetrain with a smaller ratio last year without any scrub problems.
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 13-02-2013, 07:01
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Can't say that I've personally tried this, but one stiffening idea that's been bouncing around my team for a while is using tensioned wires along each chassis bar.
