Go to Post When faced with large problems, I always see it as an opportunity to dream big. Really big. - JaneYoung [more]
Unread 12-02-2013, 13:55
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
6wd bouncing when turning
We have a problem. Our robot rocks wildly when turning at high speeds.
This year we designed our robot to have a similar configuration to a kitbot. We are 26" long by 23.5" wide using 6 wheel drive and 4" Andymark white traction wheels driven via belts off a pair of vexpro ball shifters. The center wheels have 1/8 of an inch of drop, enough that our robot can rock slightly when placed on the carpet. Our weight is distributed towards the back of the robot so that the back four wheels are usually touching the ground. Based on everything I know about drivetrains our wheelbase shouldn't have major scrub problems, but obviously it does. Are there any simple fixes we may have overlooked?
Thanks for your help,
- Alex
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 12-02-2013, 14:03
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Re: 6wd bouncing when turning
This could be caused by a flexible frame, in 2010 we had a similar problem when we built a kitbot inspired frame. The frame was not rigid enough (i.e. we did not give it adequate support for the mechanism load) and this caused the frame to flex while turning and caused all of our wheels to touch the floor making the robot "hop" while turning.
If this is indeed the problem, a few stiffener rails or a thicker bellypan may remedy the situation.
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 12-02-2013, 14:05
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Flex in the frame can cause some similar issues. If you haven't, a piece of quality 1/2" plywood for a base plate can help alleviate some problems.
edit: Beat me to it^
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 12-02-2013, 14:06
lemiant's Avatar
the Dreamer
AKA: Alex
We don't have a bellypan at all at the moment, just a frame, so that may indeed be the cause.
Would 1/4" lexan do the job? Or does it need to be stiffer?
FRC Team 4334
Unread 12-02-2013, 14:08
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Try a sheet of baltic birch plywood in 1/4 or 3/8" thickness. If you want to spend more money we have become particularly fond of XX grade garolite in 1/8" thickness
Mentor 2415
Unread 12-02-2013, 14:15
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
I've used XX before in the 1/32" and 1/16" thickness and hated it. It shatters w/o any flex and was ripped apart by the band saw.
I loved what I found with G-9 and G-10 though.
Whatever you choose, remember it is a fiberglass composite, so wear your masks and gloves when you machine it.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
1/4" Lexan should do the job. Plywood might be lighter (check the density, Lexan is pretty dense). Make sure its attached at a couple points along each side, that should help alot. Some cross bracing in the middle wheel well might help as well.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 12-02-2013, 14:22
AKA: Sean
I actually meant g-10. Just rechecked the spec sheet and that is what we have run the past 2 seasons.
Mentor 2415
Unread 12-02-2013, 14:32
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
- Alex
As said above stiffness is important in a drop wheel chassis. You could also do omins in the corners as a last ditch fix.
And always on CD a photo would help.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 12-02-2013, 14:59
Feroz1325's Avatar
1/4 inch lexan will do the trick, however 1/4 plywood will be more that adequate to keep the frame stiff. We did that last year in our sheetmetal chassis and it worked great! If you have access to a waterjet/plasmacutter/laser you may want to consider a pocketted 1/8 (or thinner) aluminum bellypan....keep time in mind as it is already week 6.
Good luck from team 1325!
Feroz Balsara
Team1325.com
Unread 12-02-2013, 18:06
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
Stiffness will be a factor, but as you mentioned in the original post, the back two wheels are the ones in contact with the floor due to CG placement. This will inherently cause scrubbing because a four wheeled drive base cannot turn without a component of movement perpendicular to that of the wheels rotation. The point of the 2 lowered center wheels is to keep weight off of the four wheels on the outside corners of the drive base (the ones that scrub) but since the rear four wheels are in contact, you essentially created a four wheeled drive base within your six wheeled base. This means the scrubbing is unavoidable, you will only be able to reduce the severity of the bumpy turns by making your frame stiffer.
Unread 12-02-2013, 20:43
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
We use flat twin-wall corrugated aluminum for our baseplate every year. It has worked well for us so far although it might be a little bit heavier than some other options.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 13-02-2013, 00:52
lemiant's Avatar
the Dreamer
AKA: Alex
The length to width ratio of either set of four wheels however is quite acceptable. We built a 4 wheel drivetrain with a smaller ratio last year without any scrub problems.
FRC Team 4334
Unread 13-02-2013, 07:01
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Can't say that I've personally tried this, but one stiffening idea that's been bouncing around my team for a while is using tensioned wires along each chassis bar.
Unread 13-02-2013, 07:04
Olin class of 2019
The point of a six wheel drive is in fact to create a smaller four wheel drive turning base while keeping a large wheelbase for stability. This is a common misconception that I've seen - that 6 wheel drive robots turn on two wheels.
They don't - they turn on four, but on a much shorter turning wheelbase than their stable wheelbase. There's a nice whitepage somewhere which describes this.
