Go to Post please....Mr. Needel is my father :rolleyes: - Greg Needel [more]
Unread 11-02-2013, 21:02
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
CAN Voltage Control
So, I am trying to control a motor using the voltage model so I can set the ramp rate to about a 10 second build-up. However, the output seems to be null. Even the indication light remained a solid yellow. Everything works perfectly over VBus in this configuration.
shootingMotor = new CANJaguar(leftMotorId, CANJaguar.ControlMode.kVoltage);
setVoltageRampRate(0.10);
shootingMotor.setX(12);
Unread 13-02-2013, 03:33
AKA: Ari Falkner
FRC #3024
Re: CAN Voltage Control
Bump
Unread 13-02-2013, 08:29
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Have you tried setting configMaxOutputVoltage(double voltage) ? I wonder if voltage control needs that set.
Unread 13-02-2013, 09:49
AKA: Ari Falkner
FRC #3024
I'll try that!
Unread 13-02-2013, 22:13
You need to call enableControl();
Unread 14-02-2013, 01:14
AKA: Ari Falkner
FRC #3024
Sweet! Thank you so much! I wish they had more documentation. Where would I find things like this?
