Go to Post If you are "retiring" the old ball, make all the lights green, hang it 8 feet in the air, line up a bunch of 'bots and let 'em shoot poofs. RoboPinata! (warning kids - don't eat the "candy" that falls out!) - Taylor [more]
Unread 13-02-2013, 09:30
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Driver Station lag, caused by -40087 error?
Hi!
My team is using 10 black Jaguar motor controllers to power 10 motors. When we set our code at startup and try to run the robot wirelessly through the driver station, it's very laggy.
We are using 100% CAN and an error in the driver station keeps coming up as:
-44087 occured at NetComm_CAN_Receive.vi:19
FRC:JaguarCANDriver timed out waiting to receive a response from a Jaguar
The number ("19") is different sometimes. Sometimes 22, sometimes 24, etc.
Is anyone else having this error? Or know how to fix it?
Unread 13-02-2013, 09:54
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Driver Station lag, caused by -40087 error?
This error is caused by a CAN timeout. Check all of your cabling and termination. Make sure you do not have multiple CAN nodes with the same ID's. If you are using the 2CAN check the web dash for CAN errors.
Also make sure you are not trying to communicate to a Jag that is not on the BUS.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 13-02-2013, 13:55
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We had this issue when our programming team was referencing a jaguar ID that did not exist in the loop, therefore the CAN bus becomes overloaded and causes you to have 1-2 second drive delays.
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 13-02-2013, 14:30
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
How are you interfacing with CAN?
2CAN, or RS-232?
If you're using RS-232, which is the serial cable that plugs into the cRIO, then I found that you have a limit of about 4 to 5 motors before it gets overloaded.
2CAN should be good to go though and not overload.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
