Go to Post Team 1114 does not design or build ROBOTS. They build AWESOME. - DonRotolo [more]
Unread 13-02-2013, 11:03
mrwright's Avatar
mrwright mrwright is offline
Coach
AKA: Michael Wright
FRC #4522 (Team SCREAM)
mrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to behold
Rookie Help- Toggle a spike
We are trying to push a button on our joystick to make the spike remain on. I am assuming that this is a toggle function. We have searched for ways to toggle using LabView but there are some conflicting methods as to which one was best.
Can anyone help point us towards a sample code that will do this?
Unread 13-02-2013, 11:11
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Rookie Help- Toggle a spike
A simple search found a number of solutions
http://www.chiefdelphi.com/forums/sh...ghlight=toggle
http://www.chiefdelphi.com/forums/sh...09&postcount=2
Omar
Unread 13-02-2013, 11:24
Omar's Avatar
Make this a sub VI and make it re-entrant. Then use it where ever you need a toggle boolean output.
Omar
Unread 13-02-2013, 18:35
Omar's Avatar
Thats the way the Boolean constants used to look.
In LabVIEW 2012 they are single [T] or [F]
Right click on the init of the Feedback and create constant. Click it to switch it between [F] and [T]
Omar
Unread 14-02-2013, 10:35
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
More information on re-entrant VIs: http://zone.ni.com/reference/en-XX/h...ts/reentrancy/ and http://digital.ni.com/public.nsf/all...256C59006B57CC
Basically, with a re-entrant VI, LabVIEW will allocate each instance of the VI like an independent sub-VI. This allows you to run all of the instances simultaneously without them interfering with each other.
To make a VI re-entrant, go to File»VI Properties (or hit crtl + I) and select "Execution" from the drop down menu.
Unread 14-02-2013, 13:54
mrwright's Avatar
Coach
AKA: Michael Wright
Thanks for the help! We got it working last night!
