Go to Post Any school official who isn't tickled pink by hundreds high school students, and teachers, and parents, and mentors spending their weekend celebrating STEM isn't a school official worth having. - Ian Curtis [more]
Unread 13-02-2013, 10:56
mrwright's Avatar
mrwright mrwright is offline
Coach
AKA: Michael Wright
FRC #4522 (Team SCREAM)
mrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to behold
Rookie Pneumatics Help
We have a couple of rookie questions related to our pneumatics system. We are trying to use spikes to control a couple of solenoid valves and we are using LabView.
We have a cylinder that needs to be retracted at the start of the match in order to be within the frame perimeter. At the start of the match we want to push a button to extend the cylinder and it remain there for the remainder of the match. We currently have a single 12 V Festo solenoid for this application.
We have got it working with the spike but it will not stay in place. We can trigger the spike but when we let go of the button it retracts. We think we need to have the button on the joystick programmed as a toggle switch. Does this sound right?
Our concerns are that for this to work correctly the spike will constantly be pulling power which will drain our batteries quicker.
So my questions are:
1.) Is it a good idea to use the spike to be constantly "on" to hold a cylinder in place?
2.) If not what should we do instead?
3.) What is the best way to program a toggle switch in LabView to keep the spike "on"?
Thanks!
Unread 13-02-2013, 11:05
Chris is me's Avatar
AKA: Pinecone
Re: Rookie Pneumatics Help
Yes, it does. Alternately, if you *never* need to move the piston during a match, you could begin your autonomous routine by setting the position to the desired state. I imagine you have something like this:
while (buttonPressed)
piston = true
which extends the piston only if the button is depressed. if you want a permanently extended piston, try just starting with piston = true.
This is not much of a problem at all. The Spike isn't seeing any load, so the current draw will not be significant. You could use the solenoid breakout if you are really concerned, but it's seriously a non-issue.
Consider using a gas spring instead of a piston for this application - these don't require power, just a mechanism to hold them shut before the match starts. Then again, it's Week 6, so you might just want to keep what you have.
Unread 13-02-2013, 11:57
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Also, if you are using the double action solenoid for this application it will stay in place (its last state) when the power from the spike is turned off.
http://www.andymark.com/product-p/am-2343.htm
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-02-2013, 12:39
funstuff's Avatar
funstuff funstuff is offline
AKA: Kat
FRC #4096 (Ctrl-Z)
funstuff has a spectacular aura aboutfunstuff has a spectacular aura about
Send a message via AIM to funstuff
(Seconding Coffeeism)
The single solenoid requires a constant signal for the piston to stay extended, where as the double would have IN/OUT logic - trigger the solenoid, it goes out and stays out, trigger again and it goes in and stays in. It would require another Spike relay (one for the in and one for the out), but may alleviate the issue of constant (albeit small) current to the solenoid.
2011-present | FRC 4096 | Technical/Mechanical Mentor
2006-2007 | FRC 624 | Electrical Subteam Captain, Strategist
2005-2006 | FRC 624 | Build Captain, Driver
2004-2005 | FRC 624 | Mechanical Subteam Captain, Driver
2003-2004 | FRC 624 | Driver
Unread 13-02-2013, 12:49
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Why are you using spikes versus the relay out card directly to the Solenoids?
Just curious.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 13-02-2013, 12:56
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Using the double action solenoid as a single solenoid with a spike is possible with only one spike. One positive end would be on the M+ and the other would be on M-. Ground can be connected to the PD board. Driving M+ would flip the solenoid valve one direction, driving M- would flip it over the other direction.
See the spike user guide for this illustration
Kevin Li
596 - Sciclones
Unread 13-02-2013, 13:01
mrwright's Avatar
Coach
AKA: Michael Wright
Thanks for the help. We only have the single solenoids so that is what we have to deal with. It sounds like it would be better to have the double acting solenoids for future use.
We will probably continue to try to use the spike and program a toggle button on the joystick.
The reason that we are using spikes is because we felt more comfortable wiring them up that way, but we are also looking at using the solenoid breakout as well. At this point in time we will probably stay with what we have now though.
Thanks for the help!
