Go to Post ...your education can be interesting and even fun. If you look a little farther down the path, you WILL "use this crap", and "this crap" can even be cool if you know how to use it. - Chris Hibner [more]
Unread 13-02-2013, 13:33
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Wink Analog Breakout Board failures?
Dear CD,
I was wondering if anyone has experienced some failures with their analog breakout board? I am programming a potentiometer for the dashboard and have been successful with Analog Input 1 but Analog Input 2 and Analog Input 3 are not reading with very similar Labview software.
I stopped testing last evening. My next step is to swap out the analog breakout board. I will report out results in a few days.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 22-02-2013, 14:13
marccenter's Avatar
Re: Analog Breakout Board failures?
CD update,
I tested another analog breakout board and received the same behavior. The issue has been found to be a software issue that is in another thread. Case closed for now
Marc Center
