Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 13-02-2013, 14:14
robbie_s95 robbie_s95 is offline
FRC #2152 (S*M*A*S*H*)
robbie_s95 is an unknown quantity at this point
can you help me understand
I am new to labview this year and have a few questions. there are no problems with a electrical we need to run a test with a joystick to see how are arm will work and nothing seems to be working correctly.if you have any solutions please let me know.
ID:	13970  Click image for larger version
Unread 13-02-2013, 14:16
Shadowfl's Avatar
Shadowfl Shadowfl is offline
AKA: William Wrenne
FRC #2152 (S*M*A*S*H)
Shadowfl is on a distinguished road
Re: can you help me understand
What problems do you specifically have?
IF (Living) = true;
Then (Learning) ;
I have a tendency to gear my self toward puns
Unread 13-02-2013, 14:22
when code is deployed we get no response from the movement of the joysticks. also we also get twitching from jaguars when the code is enabled
Unread 13-02-2013, 14:23
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
You need to declare the arm motors are four separate motor controllers - Not a robot drive.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 13-02-2013, 14:25
Thank you we were just about to test that
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Does your Arm really use 4 motor tank drive?
In LabVIEW, right click to get to the functions palette. At the very bottom is the WPI Robotics Library. Then go to Actuators, then Motors. Replace all of the 'Drive' code for the Arm with 'Motor' code.
Also, please be more descriptive. How does the system work? Does PWM 3, 4, 5, and 6 really go to the Arm? What problems are you having? What works? What doesn't work?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Should look like the following in your begin.vi
Unread 13-02-2013, 14:27
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
The first thing I see is you are using a 4 motor "Drive" for an arm. This begs the question, "Why?".
Are you using 4 motors to power the arm?
Is each one doing something different?
You might want to consider using a single motor class and "Y" cable(s) to have multiple motors doing the same thing.
See above, they beat me to it.
Unread 13-02-2013, 14:32
Thanks for the help i really do appreciate it.
