Go to Post Either way, FIRST works. You just have to keep the big picture in mind. - Lux [more]
Unread 12-02-2013, 15:00
johnnyburns35's Avatar
johnnyburns35 johnnyburns35 is offline
FRC #2487 (mechanical animals)
johnnyburns35 is an unknown quantity at this point
pic: team 2487 sayville mechanical animals 10pts :)
Unread 12-02-2013, 15:03
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: pic: team 2487 sayville mechanical animals 10pts :)
Very interesting setup! If I'm correct, do the large pistons push the plate on the robot down in order to lift it up? It's a bit hard to tell from the photo.
If so, I wonder if you'll have a problem with the rule about bumpers staying within their zone while flat on the floor... Not too much of an issue, you just have to have a very small appendage touch the pyramid before lifting.
Cool concept!
Unread 12-02-2013, 22:52
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Please be sure to cover the metal frame that contacts the floor in some kind of plastic or nitrile tread because metal cannot contact the carpet.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 12-02-2013, 23:01
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Do you have any way to make sure you are aligned to the bar? It doesn't look like you have to much room for error. From across the field that might be a bit difficult to get exactly under the bar.
Unread 12-02-2013, 23:55
we actually have our camera facing up so it is pretty easy to line up and yes the two plates to go down to the ground and push up from the bottom of the robot and to be honest im not really sure about the bumper rule on that but i sure hope that isnt the case at all that would really suck.
Team 2487 sayville high school Mechanical animals
Our team Facebook page please like it! thanks
https://www.facebook.com/pages/Sayvi...54146258036097
Unread 12-02-2013, 23:57
Unread 13-02-2013, 00:16
Im sorry to be a burden but do we have to all i see is that metal can not touch the carpet if used as a traction device or breaking fource?
Unread 13-02-2013, 00:26
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
If the inspectors think the metal dragging could damage the carpet then they will require you to cover it in someway. It has happened to a lot of teams (mine included) in the past
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 13-02-2013, 00:27
Engineering Coach
If they say it's a traction device, just put tape on it. You should be all set.
Unread 13-02-2013, 00:31
THANKS think we will do somthing with it better be safe then sorry
Unread 13-02-2013, 01:23
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Wouldn't it have been simpler to just flip the pistons, put hooks on the ends and pull yourself up instead?
It seems like it would be much easier to line up since you could drive around with hooks extended, line up against the tower, and pull up. With a bottom lift you have to be absolutely lined up before you can lift, and if you're off center at all you have to start over.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 13-02-2013, 08:29
https://www.facebook.com/pages/Sayvi...type=2&theater
Unread 13-02-2013, 12:20
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Nice Work Guys! Your team has come a long way in a few short years.
Well Done.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 13-02-2013, 16:10
Bob Steele's Avatar
AKA: Bob Steele
Cool concept!
I would think that everyone needs to remember that in climbing you have to make contact with the zones... and zone 0 is the floor... You are in the act of climbing when you are at the pyramid in zone 0 That would count as contact ...
The definition of having to make contact was changed in the first week to include Zone 0 which is the floor. This was done so you couldn't reach up to zone 2 while still on the floor because you can't be contacting three zones at the same time.
i think your approach looks like a great solution ...
Good luck at the competition...
Unread 13-02-2013, 20:24
Thank you to everyone looking forward to seeing you all at the competition!
