Go to Post But then again, no one's robot ever is fully working to how they want it before the first tournamant. - #1Transgirl1140 [more]
Unread 13-02-2013, 17:16
THEmigthyI THEmigthyI is offline
FRC #1429
THEmigthyI is an unknown quantity at this point
How to connect two digital sidecards onto the C-rio?
I imagine that you would just add another 9403 moduel onto the fourth slot in the C-rio, but I'm not sure if this is the correct way.
Unread 13-02-2013, 17:31
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Re: How to connect two digital sidecards onto the C-rio?
Yes and make sure you reimage the CRIO. When you do this all 4 slots should be green with the corresponding module number. In the programming make sure you set which motors, relays, etc.. go to the correct sidecar module.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 13-02-2013, 17:34
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
edit: I have been made aware that there are no quantity limits on KoP items this year, please disregard me post if you already read it!
Unread 13-02-2013, 23:29
There's no need to reimage anything. A 4-slot cRIO will handle whatever module you put in slot 4.
If you're using an 8-slot cRIO, a second digital I/O module goes in slot 6.
Unread 13-02-2013, 23:41
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Make sure you specify which module is which when coding. The first one is 1 and the second one is 2.
If you're making a Talon in PWM 3 on Sidecar 1 (in slot 2), the code (in Java) is:
 Talon talon = new Talon (1, 3);
A Jaguar on PWM 5 on Sidecar 2 (Slot 4 or 6) would be created as:
 Jaguar jag = new Jaguar (2, 5);
