Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 13-02-2013, 19:37
CauseImAzn CauseImAzn is offline
FRC #4500
CauseImAzn is an unknown quantity at this point
Exclamation 5v Digital Sidecar
The 5v out is not sending signal and the light is not lit at all. Is there any thing we can do short of buying a new sidecar?
EDIT: The 6v light is lit and so is the battery light, it is just the 5v light that is not lit.
Unread 13-02-2013, 20:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 5v Digital Sidecar
Have you verified that you have 12V power to the sidecar? As in actually measured 12V power at the connector to the sidecar?
Unread 13-02-2013, 20:31
FRC #4500
We have, we took a multi-meter to where the sidecar is getting power and it was reading 12 volts.
Unread 13-02-2013, 20:38
Other possibility is that you're shorting the 5V to ground somewhere. If you disconnect everything from the sidecar and you still don't have a 5V LED, then yes, your sidecar is probably dead and you need a new one. Find out if there are any veteran teams near you, as they usually have a few extra sidecars laying around. Or you can buy one from Andymark.
Unread 13-02-2013, 20:41
DonRotolo's Avatar
Back to humble
FRC #0832
After everything is disconnected, be sure to turn the sidecar upside-down to loosen any metal shavings that might be the problem. Spray air is a good idea too.
