Go to Post We were just going to drive our robot into the alliance station wall until the match ended, but now we might be changing up how we approach the teleop period. - PayneTrain [more]
Unread 13-02-2013, 20:29
Team 4698 Team 4698 is offline
AKA: Jarret
FRC #4698
Team 4698 is an unknown quantity at this point
cRIO Imaging Problem
Our cRIO will not continue past the Rebooting stage in the cRIO Imaging process. It also does not detect the 3 modules in the cRIO.
Our IPs are correct, the wires are in the correct places, and getting power.
What should I do?
Unread 13-02-2013, 20:32
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: cRIO Imaging Problem
Are you using a 4 or 8 slot cRIO?
And are you going through your wireless bridge, or are your communication wires going directly into the cRIO?
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 13-02-2013, 20:33
AKA: Jarret
FRC #4698
We're using a 4 slot cRIO, and also wiring directly.
Unread 14-02-2013, 09:25
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Do you have the modules powered? Such as through the breakouts and the sidecar?
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
Unread 14-02-2013, 10:02
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
You might want to try plugging in a serial cable and getting the boot up information. This will tell you weither or not it is actually rebooting, or if it is failing to do such. this should also display any errors you get.
"you can build a perfect machine out of imperfect parts" -Urza
Unread 14-02-2013, 10:55
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Attach a router or the new bridge between the cRIO and the computer. Sometimes the reformat will temporarily disconnect the computer and cRIO, and as a result some computers don't like it.
