#16
Re: Scheduler.getInstance().run() throws a null pointer
Can you confirm that you aren't seeing the update?
Thanks, Brad |
#17
I see the updated WPILibJ plugins (version 429) when I reload the catalog
#18
are these WPIJavaCV updates or WPILibJ updates? WPIJavaCV never worked for me and theres no WPILibJ updates (all are version 2013.0.417)
#19
http://first.wpi.edu/FRC/java/netbeans/update/Release you'll see the file updates.xml. That is the file that controls the update process and it should be at version 429. The SmartDashboard also updated both in the NetBeans update and in the plugin update. Brad |
#20
There are instructions here: http://wpilib.screenstepslive.com/s/...elopment-tools
#22
Can someone outline the solution for this issue? We're encountering it as well, and tried what we read in this thread - restoring that autonomous example command, updating the libraries... any help would be appreciated!
