Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 13-02-2013, 21:09
anonymousguy31's Avatar
anonymousguy31 anonymousguy31 is offline
FRC #1160 (Titanium Robotics)
anonymousguy31 is an unknown quantity at this point
cRIO Imaging Error
I am currently trying to image my teams cRIO using the imaging tool but an error appears every time saying- "cannot assign IP adress- make sure that the reset ip switch is off". The switch is off, my computers ip is set correctly. I heard that you are supposed to do this using a crossover cable (I was using ethernet) so I tried to use a wireless bridge- same error. Any ideas?
Unread 13-02-2013, 23:04
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
Re: cRIO Imaging Error
It's not recommended to image over wifi. I believe you should just use ethernet and not a crossover. Double check the documentation at the link below for correct IP settings. There is a virtual switch for IP reset for 4 slot or a physical switch for 8 slot cRio.
http://wpilib.screenstepslive.com/s/...ging-your-crio
