Go to Post [when asked where to learn about robot parts] ...some forum called Chief Delphi. I hear the people there are pretty knowledgeable about this robotics thing. - EricH [more]
Unread 13-02-2013, 23:10
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Victor 888 motor controllers??
Can you Program Two Victor 888 motor controllers To a Button On The Joystick
Unread 13-02-2013, 23:12
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Victor 888 motor controllers??
Yes, or use a pwm Y cable.
Unread 13-02-2013, 23:16
AKA: Reginald
Thank and is there any kind of way for us to change the speed of our motor using the Dial on our Controller Attack 3 Joystick (fc13-123)
Unread 13-02-2013, 23:31
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
victor.set((joystick.getZ() + 1)/2);
in Java/C++.
Unread 13-02-2013, 23:34
AKA: Reginald
in Java/C++.
My Team use LabView
Unread 13-02-2013, 23:42
cgmv123's Avatar
AKA: Max Vrany
My Team use LabView
That code still works, you just have to translate it.
Unread 13-02-2013, 23:47
AKA: Reginald
Can you tell me how to do that????
Unread 14-02-2013, 00:04
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
This should do what cgmv123 had in Labview, I also added a bit that will have Button 1 control if the motor is On(With output from throttle) or off. Given that you were asking about setting a motor from a button in the first post.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 14-02-2013, 00:18
AKA: Reginald
Thank For The Help.
Unread 14-02-2013, 14:27
AKA: Reginald
where do you go to,to find the button vi to program the 888 motor controllers ?
Unread 14-02-2013, 15:02
Nirvash's Avatar
AKA: Bryan
FRC #4676
The button VI in the image will be in WPI Robotics Library >Robot Drive>Joysticks.
Also, a neat thing with the image I linked, is that you should be able to drag it into your VI and it should load as code.
Unread 14-02-2013, 17:28
AKA: Reginald
now i just did that and its not turning into code :/
Unread 14-02-2013, 17:35
Nirvash's Avatar
AKA: Bryan
FRC #4676
Huh, that is odd, did you save the file to disk first?
Unread 14-02-2013, 17:49
AKA: Reginald
nope, but the computer i'm using doesn't have a disk drive
Unread 14-02-2013, 17:54
cgmv123's Avatar
AKA: Max Vrany
He meant the hard drive or the local drive.
