Go to Post "You are the lead programmer now, therefore everything that goes wrong is your fault. When anything good happens its the teams fault." "But what if the robot spontaneously combusts?" "Your Fault." ~Borna - CodeTBone [more]
Unread 13-02-2013, 22:42
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Code messing up
So today we were trying to test some code.
We deployed it to the cRIO from LabView on our computer with no issues.
However we tried to control the robot was it had finished loading and we were getting a "No Robot Code" error.
Any ideas?
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 13-02-2013, 23:10
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: Code messing up
Im having issues like this, i can deploy code once then i can't redeploy again and the code is not functioning correctly
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
Unread 14-02-2013, 00:30
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Code messing up
Any ideas?
Are you building and running as startup, or just running the code temporarily from Robot Main?
I have a feeling you're crashing the cRIO. Try to run the code straight from Robot Main and see if it gives you an error of some kind.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 14-02-2013, 00:31
RyanN's Avatar
RyanN
Re: Code messing up
Have you been placing all of your hardware from the begin file in the finish file to close the references?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 14-02-2013, 01:22
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Re: Code messing up
Begin: We opened joysticks, drive motors, and a shooter motor.
Teleop: Tank Drive and a simple control for our shooter
Finish: Closing opened items
So we are deploying straight from robot main. We are direct connecting to the cRIO 8-Slot. Should we try going through the bridge?
Unread 14-02-2013, 08:31
RyanN's Avatar
RyanN
Re: Code messing up
Can you answer my previous question? The message you replied to was for ProgrammerMatt.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 14-02-2013, 08:57
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Re: Code messing up
Sorry bout that...
I'm running it from Robot Main and I'm opening everything.
Should I trying making a real-time app?
Unread 14-02-2013, 09:15
RyanN's Avatar
RyanN
Re: Code messing up
Sorry bout that...
No. If it's dropping like that while running, then you must be doing something really wrong.
Are you referencing a second module of some sort without there being one? Such as Digital Module II? Have you tried reimaging it and formatting the controller?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 14-02-2013, 21:35
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Re: Code messing up
So we built a an application and it worked. Thanks for the input.
