Go to Post Someone want to channel their inner Mark Leon and do the math? - Billfred [more]
Unread 14-02-2013, 09:28
B Dot's Avatar
B Dot B Dot is offline
Play, Rest, Repeat
AKA: Bryan
FRC #1706 (Ratchet Rockers)
Team Role: Driver
B Dot is an unknown quantity at this point
Linear Actuator
Hello, we have been shopping around to find a linear actuator that would suit our needs and i was wondering if this one is legal.
http://www.robotshop.com/productinfo...-81&lang=en-US
Thank you in advance for your help
Unread 14-02-2013, 09:32
Andrew Lawrence
Posts: n/a
Re: Linear Actuator
You are allowed unlimited linear actuators, ONLY if the stroke is 1 inch or less.
Unread 14-02-2013, 09:33
B Dot's Avatar
Play, Rest, Repeat
AKA: Bryan
Team Role: Driver
Re: Linear Actuator
And what if the stroke is over one inch?
Unread 14-02-2013, 09:35
Andrew Lawrence
Posts: n/a
Re: Linear Actuator
Then I don't believe it is allowed unless it utilizes one of the legal motors.
Unread 14-02-2013, 09:38
B Dot's Avatar
Play, Rest, Repeat
AKA: Bryan
Team Role: Driver
Re: Linear Actuator
So if I modify the linear actuator above to use an am-0912, would it then be legal to use in competition?
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Linear Actuator
4.1.7.1 R32 (the relevant part) part reads: "Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)" are allowed.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 14-02-2013, 09:41
mathking's Avatar
AKA: Greg King
Re: Linear Actuator
If you are looking for something with a longer stroke, and don't want to use pneumatics, try some variation on a CAM. Here is some video of the system we are using, there are plenty of others:
Here is a video of it in operation.
Here is the limit switch we use to stop it.
Unread 14-02-2013, 09:43
mathking's Avatar
AKA: Greg King
Re: Linear Actuator
Depending on exactly what you do, yes is probably the answer. In other words if you provide the power to actuate from the 9015 motor then it is probably legal.
Unread 14-02-2013, 09:45
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Linear Actuator
things are being confused here:
there are electric solenoid linear actuators
and there are electric motor driven mechanical linear actuators.
the electric one has to meet R32
the mechanical one has to meet the motor rule, meaning you have to refit the motor.
Ed Barker
Unread 14-02-2013, 09:47
B Dot's Avatar
Play, Rest, Repeat
AKA: Bryan
Team Role: Driver
Re: Linear Actuator
So this means that the linear actuator that i provided a link to just has to be outfitted with a legal motor, such as the am-0912?
Unread 14-02-2013, 09:51
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Re: Linear Actuator
Replace the motor with a legal motors as listed in the rules and as long as the part is less then $400 you are good to go.
Unread 14-02-2013, 09:57
mathking's Avatar
AKA: Greg King
Re: Linear Actuator
Just be aware that replacing the motor on the actuator with another motor may not be a simple task.
Unread 14-02-2013, 10:18
ebarker's Avatar
AKA: Ed Barker
Re: Linear Actuator
yes, what they said..above
Ed Barker
Unread 14-02-2013, 11:10
B Dot's Avatar
Play, Rest, Repeat
AKA: Bryan
Team Role: Driver
Re: Linear Actuator
Thank you all for your help
