Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 12-02-2013, 22:36
odogollie odogollie is offline
Lead Programmer
AKA: Oliver Shanklin
FRC #4068 (Aperture Robotics)
odogollie is an unknown quantity at this point
cRIO Taking To Long To Respond
Hello!
So here is the problem. On the Driver Station on the left side where you would see the voltage and stuff, we are not getting a robot com green light. But in the Diagnostics section of the Driver Station it says we have Coms with the robot. Also I was able to pick up the cRIO in the Imaging tool and reimage it. And again connecting to cRIO from LabVIEW was fine and dandy. I was able to upload the code to the cRIO but I had lots of messages saying "Waiting for response from Real Time Target (cRIPO)" or something close to that. It took probably 3 times longer then normally. We do use the Classmate to upload the code and do all of the driver stuff. So being that the laptop was from last year, I reimaged that as well. I'm not sure what is going on. Someone please help us!
Thanks!
Unread 13-02-2013, 13:20
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
Re: cRIO Taking To Long To Respond
First things first, did you get the 5.1 LabVIEW update from FIRST? This update was released not too long ago, and it fixes the "Waiting for cRIO to Respond" bug.
Unread 14-02-2013, 04:28
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Hmmm we have been having the same issue. We updated to 5.1, but it still takes something like 10 minute to run the code because of the Waiting for cRIO to respond messages...
Unread 14-02-2013, 08:47
I don't have enough information to help. You may want to contact NI support. Or post again with more information about when this occurs and if it succeeds.
Greg McKaskle
Unread 14-02-2013, 08:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We're seeing this same issue, but in a more limited sense.
When we go to deploy code the 1st time, it takes the normal extended period of time. Subsequent deploys, which usually go very quick, now stop just before they reach the end and a 'waiting for cRIO' message appears. Usually, waiting 10 to 15 seconds results in the download completing. This never happens on the same VI or file, and we double checked the default code. This is happening across 4 cRIO's and 3 computers.
We are directly linked from the computer to the cRIO. It is a real error message - I have pinged the cRIO through this period and the pings are not returned while the 'Waiting' message appears.
Unread 14-02-2013, 09:10
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
We are seeing the same thing here. Usually the last 3-5 VI's to download to the controller take much longer than the rest of them. Between them, the "waiting" message can be seen.
I'm right 90% of the time, so why worry about the other 3%?
Unread 14-02-2013, 10:18
I don't normally see this, but perhaps your programmers are prolific. If you want to share your project, PM me and I can look at it a bit.
As you probably know, the Waiting dialog is really just a heartbeat notification. It is actually changeable in the Target Properties.
Greg McKaskle
Unread 14-02-2013, 10:52
Tom Line's Avatar
Greg - should loss of the heartbeat stop the download temporarily? None of our VI's are particularly large.
Unread 14-02-2013, 21:42
I have seen operations like loading a complex or large VI cause the dialog. In particular, the VIs load from bottom to top, and as the top VIs come into memory, I've seen them take the longest.
Greg McKaskle
Unread 15-02-2013, 15:00
Lead Programmer
I loaded the code on to another laptop and uploaded it to cRIO and we had no problem at all. We were spinning up motors and servos and everything was fine. I have LabVIEW on the classmate fully up to date. I will probably image the Classmate to last years image and reload labview. I will post my results when I get the chance.
