Go to Post Now that the robot is shipped, maybe I can get to bed before the alarm clock goes off =] - DarMagi [more]
Unread 13-02-2013, 21:28
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
we have servo problem and programming
hiii
our robot have shooter that has a servo that pushes frishbee to the spining tires.so we created a servo with a arm that pushes it and i put jumpers too and i programmed it as-well but i dont know for some reason its not working can anybody please help us asap.... thanx
Unread 13-02-2013, 21:37
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: we have servo problem and programming
Well here are some things you can troubleshoot. Did you add the jumper on the Digital Side Car for the Servo. Is the Digital Side Car 3 lights on indicating it is powered?
Unread 13-02-2013, 21:40
AKA: Akash
FRC #4684
yes it is
Unread 13-02-2013, 22:11
MagiChau's Avatar
AKA: Michael Chau
Could you post the code you wrote?
Unread 13-02-2013, 22:43
AKA: Akash
FRC #4684
here it is
Unread 14-02-2013, 10:25
Originally Posted by akash992391 View Post
...its not working...
What do you expect it to do? What is it doing instead?
What kind of servo is it, and how do you have it wired? What physical mechanism is it attached to? What have you added to Begin.vi and Teleop.vi to control it?
Unread 14-02-2013, 11:08
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
That looks like a very long and heavy arm for such a small servo. It is possible that the problem is mechanical or electrical, and programming related at all. The servo may have even been damaged by being pushed into too heave of a load. Do you have any way of testing the servo separate from your code and the CRio?
Does your team have an RC controller or servo tester? If not, do you have another servo to try? If so, I would suggest trying a new servo with nothing attached to test your code and only then introducing something with a mechanical actuator. That way you decouple any mechanical problems from the software debug.
This is the zeroth day of the rest of your life.
Unread 14-02-2013, 12:14
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
So, does the servo move without the big piece of Al. attached to it?
I just checked our teams code, as we are using the servo for the camera adjustment. The difference we have is instead of just selecting the data to feed the set angle block, we have the selection going to a case structure and selecting between two set angle blocks with the data being feed as constants.
I am not a Labview literate, but I see nothing that you are doing wrong in but it is different that what we have, and ours is working.
The sooner we get behind schedule, the more time we have to catch up.
Unread 14-02-2013, 13:02
Here's something to try.
On the Driver Station Operation tab, put the robot into Test mode and Enable it.
Then on the Dashboard Test tab, you will see a listing of all the things you opened in Begin.vi.
Find the servo and click on value.
Controls will appear at the bottom of the tab window that let you move the servo to see if it responds properly.
If it appears in the Test window, then the servo was Opened.
If you can control it, then the wiring is good.
Unread 14-02-2013, 14:29
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
If it appears the the Test window, then the servo was Opened.
I love this! Thanks for sharing!
But as to the servo, I would try only recalling one joystick 3, having two might give the not a headache.
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 16-02-2013, 11:56
AKA: Akash
FRC #4684
its still not working
Unread 17-02-2013, 01:04
Until you tell us clearly what you've tried, and what results you've gotten when you tried it, all we can do is suggest the same things we've already suggested.
