Go to Post [I]'Twas the night before ship day, And all through the shop, Not a creature was stirring, Not even[/I] -- Naah, they'll never believe that. - GaryVoshol [more]
Unread 14-02-2013, 14:59
akgsteelers's Avatar
akgsteelers akgsteelers is offline
Manufacturing/Pit Lead
AKA: Andrew
FRC #0384 (Sparky)
akgsteelers is an unknown quantity at this point
6 days left!!!
There are only 6 days of build season left. MAN how time flies. Many long nights, many tired mornings, but it will all be worth it. When you first walk into the regional a great sigh of relief comes from many. From when your robot first hits the practice field to the final match, you should always be proud of what you have worked on, no matter if you win or loose, you had fun in the process with your friends and your mentors.
Good luck to all and I will see some of you at the Virginia Regional!
SPARKY 384
Unread 14-02-2013, 17:55
Damiaen_Florian's Avatar
Damiaen_Florian Damiaen_Florian is offline
Do It Until You Can't Get It Wrong
FRC #0195 (The Cyber Knights)
Damiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to all
Re: 6 days left!!!
Good luck to you as well in finishing your robot in time, it does always seem to be a struggle And also looking forward to seeing you at the Viriginia Regional!
