Go to Post I care that teams took some time to put in safe guards to prevent shrapnel hitting people because I'm selfish and I enjoy the use of all of my limbs. - Andrew Schreiber [more]
Unread 14-02-2013, 15:33
e10 e10 is offline
FRC #3949
e10 is an unknown quantity at this point
Relays not working
We are having an issue getting our relays to work. We are using a spike relay to move a motor. We believe everything is connected correctly, as the light on the relay is on. Thus we think the problem is in our code:
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive syste0m
	Relay feeder;
public:
	RobotDemo(void):
		feeder(5, Relay::kForwardOnly)
	void OperatorControl(void)
		while (IsOperatorControl()){
                                     feeder.Set(Relay::kOn);
		           feeder.Set(Relay::kForward);
Unread 14-02-2013, 16:36
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Re: Relays not working
Get rid of the line that says
and try that.
I've never written that line ever, and all you should need is the feeder.Set(Relay::kForward);
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 14-02-2013, 16:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Relay.Value has 4 values: kForward, kOff, kOn, and kReverse. These each do something specific with the relay.
kForward drives it forward - in other words, it connects M+ to your +12V input, and M- to the ground input.
kReverse drives it backwards - M+ to ground, M- to +12V.
kOff turns off the connections - it connects both M+ and M- to ground.
kOn turns on both connections - it connects both M+ and M- to +12V.
In terms of FIRST use with motors, all you really need is off, forward, and reverse. Using it with the compressor, all you need is off and forward.
However, in some low voltage situations (like pneumatic solenoid valves or LED lighting) you can run the ground wire directly into the power distribution board's ground, and run the positive wire to either of the relay outputs.
In the case of a 2-position pneumatic solenoid hooked up to a single cylinder, this means you always drive the relay forward or reverse, and the cylinder will move accordingly - setting it to off or on won't do anything.
In the case of LED lighting, this can allow you to turn on different sets of LED's - for example, forward might turn on red LED's, while reverse turns on blue ones. off would turn them both off, while on would turn them both on.
2016: Lake Superior WFFA
Unread 14-02-2013, 17:49
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
It's probably just us, but we couldn't get the relays to work unless we were using a pointer...
feeder->Set(Relay::kForward);
Unread 14-02-2013, 20:38
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
You are missing the line
myRobot(1,2)
Under
RobotDemo(void):
and above
That initializes the robot drive and the feeder
	Relay feeder;
public:
	RobotDemo(void):
                           myRobot(1,2),
Brian K
Team 1225 Robotics Mentor
