Go to Post Remember, just because you saw it on ChiefDelphi, doesn't make it true. - Karthik [more]
Unread 30-01-2013, 15:42
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
NetBeans Debugger not working this year?
The past two years we have been able to use the debugger in NetBeans to step through our Java code running on the Robot.
This year, we cannot get it to work.
We set a breakpoint and run in debug mode. Windows Firewall comes up asking us to verify the access. We click 'Allow', but NetBeans cannot connect to the process on the robot.
The error is something like "Connection Refused" - in the debug console.
Could someone else give this a try and let me know if you can get it to work?
We're using NetBeans 7.2.1 with the 2013.0.417 FRC Plugins. I know we have a 2013 cRIO image - I think it is the latest.
thanks - sh
Unread 01-02-2013, 01:10
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: NetBeans Debugger not working this year?
Yes, my team has the same problem, we got it working once, them ot stopped for no reason
Unread 02-02-2013, 17:02
kylevedder kylevedder is offline
Programmer
AKA: Kyle Vedder
FRC #0467 (Shrewsbury Colonials)
kylevedder is an unknown quantity at this point
For some reason, debugging only works when wired into the robot, not over wireless. Try plugging into the robot bridge with and ethernet cable.
Unread 11-02-2013, 12:52
I could not get debugging to work during this year's beta test, and reported it. However, no one else complained about it, so I'm not sure if that means nobody debugs with netbeans, or that I was the only one with a problem.
Unread 11-02-2013, 15:26
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
It was working for me when I was on my laptop (using wireless, ip was set to 10.xx.yy.12, subnet was 255.0.0.0)... So idk why its not working for you all?
Unread 12-02-2013, 20:37
AKA: Brad
#0190 ( Gompei and the Herd)
I just tested the current release using these steps:
http://wpilib.screenstepslive.com/s/...-robot-program
Be sure to set a breakpoint at the beginning of the program before you attach the debugger. You should see it stop at the breakpoint line and you'll have control to single-step or the other debugger operations.
Please post if it doesn't work.
Brad
Brad Miller
Robotics Resource Center
Unread 13-02-2013, 01:42
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
We have gotten ours working several times from both Windows and Linux boxes, however in all cases the computer had to be tethered.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 14-02-2013, 17:23
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Subnet needs to be 255.255.255.0 for it to work, otherwise you will have no communication with that computer.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 14-04-2013, 14:26
Multiple people on my team tried to get the debugger running wirelessly, with no success. I just tried it tethered and it worked.
