Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
Unread 14-02-2013, 16:35
sthreet's Avatar
sthreet sthreet is offline
AKA: scott threet
FRC #4692
sthreet is an unknown quantity at this point
Displaying camera image and getting the dashboard to display in the driverstation
So i've been looking for a good tutorial for both of these things and i think that I have the camera displaying the image, but i'm not 100% sure whether I have it displaying on a dashboard project I created (can't test right now) and I have no idea how to deploy the dashboard to the driver station. Is their anything I have to change from the basic dashboard project, or in the camera IP? And how do I deploy the dashboard to the driver station?
Unread 14-02-2013, 17:43
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Re: Displaying camera image and getting the dashboard to display in the driverstation
Can you confirm that your camera feed is working with the default dashboard project that comes with the driver's station update?
Unread 14-02-2013, 18:20
sthreet's Avatar
AKA: scott threet
FRC #4692
I'm not sure their was a dashboard project, I just created a new one... I think we've done four updates, does that sound right or did we miss one?
Unread 14-02-2013, 18:42
propionate's Avatar
AKA: Stephen
When you download this update...
http://joule.ni.com/nidu/cds/view/p/id/2263/lang/en
... on your driver station laptop it will create a shortcut on the desktop to open the default dashboard project. If you can't find this shortcut, and think you downloaded the update already, check the Program Files(x86) folder and look for "FRC Dashboard." The default dashboard .exe will be inside.
Unread 14-02-2013, 18:51
sthreet's Avatar
AKA: scott threet
FRC #4692
Ok, but now how do I deploy it to driver station? And is their any code that i need to modify to make it detect my camera? EDIT: And how to I modify the code for it? It looks like the dashboard I created but I can't get to the code... (dashboard was a default project template thingy...)
Unread 14-02-2013, 19:00
propionate's Avatar
AKA: Stephen
I am not sure what you mean by "deploy it to the driver station." Could you elaborate? The .exe that comes with the driver station update is an already built version of a LabVIEW Dashboard Project. There is no need to do a deployal of any kind in order to run it.
You should not need to modify any code for the default exe to receive video from the network camera on the robot. If you DO want to modify it for another reason, you will have to start a new dashboard project, edit it, and then build it. Then you can run the exe that is created.
Unread 14-02-2013, 19:05
sthreet's Avatar
AKA: scott threet
FRC #4692
The dashboard doesn't show up on our driver station... How do we get it to do that?
Unread 14-02-2013, 19:21
Too many answers and not enough to the question.
Let's assume that you created a new Dashboard project.
You went to Build Specifications and ran Build.
There are several ways to get it to run.
Pick one:
  1. Start it yourself. You'll find it at Documents\LabVIEW Data\builds\FRC Dashboard Project\FRC PC Dashboard
  2. Copy the executable (above) to where the Driver Station expects to find it (C:\\Program Files (x86)\FRC Dashboard).
  3. If you left the new project name default, then in the Driver Station app. you can choose the LabVIEW button on the Setup tab.
  4. Right-click on FRC PC Dashboard under Build Specifications, and choose Properties. Change the Destination Directory to C:\\Program Files (x86)\FRC Dashboard, and whenever you build it will replace the existing default Dashboard with your new one.
  5. There are other ways...
If you want it to run on another machine, then you'll need to copy the executable over to it (#2 above).
Last edited by Mark McLeod : 15-02-2013 at 13:52. Reason: Added #4 so I could reference it later.
Unread 15-02-2013, 13:21
sthreet's Avatar
AKA: scott threet
FRC #4692
Originally Posted by Mark McLeod View Post
[*]If you left the new project name default, then in the Driver Station app. you can choose the LabVIEW button on the Setup tab.
Thanks, I didn't leave the name default but for some reason i switched it over to "labview" and changing it back to default changed it. That's why it wasn't showing up above the bottom part...
Unread 15-02-2013, 13:45
That makes sense.
The LabVIEW button only looks for the default project name.
The Default button looks for C:\\Program Files (x86)\FRC Dashboard/Dashboard.exe
It won't be your new Dashboard project that's running though unless you either move the new executable into FRC Dashboard or you can go into the Build Spec properties and set the Destination directory to C:\\Program Files (x86)\FRC Dashboard/Dashboard.exe (see #4 added to the earlier post).
Unread 15-02-2013, 23:32
sthreet's Avatar
AKA: scott threet
FRC #4692
That makes sense.
The LabVIEW button only looks in for the default project name.
True, but the only difference between the new one i created (didnt' edit anything, atleast i know how to though) and this one is that the one i created had some weird stuff going on wtih part of it being offscrean when i ran it...
