Go to Post The sponsor had a $2000 sheet of aircraft aluminum in their scrap bin? Do they also blow stacks of dollar bills off their loading dock with a giant fan? - Richard Wallace [more]
Unread 14-02-2013, 21:47
zackd97 zackd97 is offline
FRC #4102
zackd97 is an unknown quantity at this point
Limit Switch Problems
I'm having trouble creating a functional program for limit switches. The idea is that there is an arm that will move forward, trigger a switch at its limit, and move back until it triggers another switch in the ready position. I think the problem is either the switches themselves, my if statements, or how I'm trying to take the values of the switches. Right now when I run the program the arm will move back without stopping. The arm will continue to move back until I restart the cRio, completely ignoring the switches. I tried changing the if statements to false, but when I do that the arm just twitches for a second. If anyone can find what I'm doing wrong or give a better solution, that would be awesome.
The code can be found here- https://github.com/zackd97/RobotProject4
Sorry if the github repository sucks, I'm pretty new at this.
Edit: I forgot to mention that all of the issues are in the loader subsystem, pushfrisbee command, readyposition command, and the frisbeeload command group.
Unread 17-02-2013, 00:36
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: Limit Switch Problems
I'm not a pro at reading robotbuilder code, but in just taking a cursory glance at your loader subsystem file, I see the following code...
bool Loader::GetReadySwitch(){
	readySwitch->Get();
bool Loader::GetEndSwitch(){
	endSwitch->Get();
While I didn't study the way these functions are used, it would seem that they are not doing you any good... GetReadySwitch() and GetEndSwitch() should *return* a boolean. They are not returning anything. They each go and 'Get()' the value of the digital inputs, but they don't return them... a corrected version might be:
	return readySwitch->Get();
	return endSwitch->Get();
Without returning anything, whomever calls those Get*Switch() functions won't get any info back.
Also, please look at your compiler warnings. The compiler should warn you that you have defined a function as a 'bool' but you returned no value at all. Warnings from compilers are often times very important - especially when you're less experienced.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
