Go to Post Thank you for Recycle Rush, the largest FLL game ever. - Dan Petrovic [more]
Unread 14-02-2013, 22:05
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
programmed DC motor in degree..
hiii
is there any way to programmed DC motor to certain degree???
Unread 14-02-2013, 22:18
Re: programmed DC motor in degree..
You need a feedback sensor to do that.
Usually a potentiometer or an encoder depending on what rotations you want to allow the motor to have.
Unread 14-02-2013, 22:36
AKA: Akash
FRC #4684
do they provide encoder sensor in kitof parts
Unread 14-02-2013, 22:55
Not inside the Kit totes.
You can get potentiometers at electrical supply places like Radio Shack.
Unread 14-02-2013, 23:02
AKA: Akash
FRC #4684
can u help mw with this.i have servo but how to programmed that i tried everything but doesn't work on servo can u help me please how to programmed servo i have all electical is good connected but the big problem is progrmming idk please help us....thanx
Unread 14-02-2013, 23:16
A servo needs a special jumper on the pair of pins right beside the PWM output the servo is connected to.
This picture (http://www.chiefdelphi.com/forums/at...3&d=1295532854) shows two white jumpers on PWMS 1 and 2.
The code looks like this:
You can check your servo using Test mode on the Driver Station and the Test tab on the default Dashboard.
Unread 14-02-2013, 23:39
AKA: Akash
FRC #4684
I tried same wiring with jupers and code still didnt work ...
Unread 15-02-2013, 11:20
BenGrapevine's Avatar
BenGrapevine BenGrapevine is offline
Head Programmer
AKA: Tony Simmering
FRC #2549 (Millerbots)
BenGrapevine is an unknown quantity at this point
Check to make sure everything is plugged in and that the in the drivers station the joystick you are using is set as the first one in the list. Also make sure you're referencing of the name is consistent throughout.
Millerbots Team 2549
orange and blue
