Go to Post A link to BoardGameGeek in a FRC blog post... My worlds are colliding, and it's great! - rwodonnell [more]
Unread 14-02-2013, 21:22
AKA: Brad
#0190 ( Gompei and the Herd)
Camera and the SmartDashboard
For those trying to use the camera plugin with the SmartDashboard and having crashing problems...
Can you try the newest version of the SmartDashboard installer here:
http://firstforge.wpi.edu/sf/frs/do/.../frs.installer
It has a few bugs fixed. There seems to still be a memory problem that we're trying to track down, but it seems to run for about 20 minutes without problems. Please make sure you are doing all the things described on this web page (32 bit java, setting IP address, etc.)
http://wpilib.screenstepslive.com/s/...sion-installer
Also, you should make sure that you are not running 640x480 at 30FPS or you will overrun the bandwidth for 2013. Remember that the field will limit each teams available network bandwidth to 7Mbs. We were testing at 320x240. I believe the FRC Bridge Configuration Utility will do the appropriate Quality of Service (QOS) settings to your DLink access point to simulate the field bandwidth throttling. It is described here:
http://wpilib.screenstepslive.com/s/...o-for-home-use
This is only for those who are using the SmartDashboard camera plugin to display the Axis camera on their SmartDashboard screens. This doesn't effect the SmartDashboard.jar file for anyone using it only for displaying data or Test mode objects.
Brad
Brad Miller
Robotics Resource Center
Unread 14-02-2013, 22:57
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Camera and the SmartDashboard
Our camera is not showing up on the dashboard. It worked beforehand (and crashed afterwards like everyone else).
All opinions are my own.
Unread 14-02-2013, 23:46
AKA: Brad
Do you mean it worked before this recent 1.0.5 update? And crashed immediately once you applied the update? What camera and what resolution/framerate/compression settings are you using?
Brad
Brad Miller
Unread 15-02-2013, 00:01
AKA: Joel Gallant
Fixed it using the video stream option. I'll update you if it crashes the dashboard.
Unread 15-02-2013, 12:19
AKA: Joel Gallant
It crashed after about 30 minutes in the "Video Stream Background" thread.
Unread 07-03-2013, 01:09
pr0ph3t pr0ph3t is offline
Programming and Controls Mentor
AKA: Jeff Ousley
FRC #3528 (Up Next)
pr0ph3t is an unknown quantity at this point
We're also running into this problem. What do you mean by 'video stream option'? In the camera config?
