Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread 14-02-2013, 12:54
AutoBotAM AutoBotAM is offline
AKA: Christian Reese
FRC #2077 (Laser Robotics (Laserbots))
AutoBotAM is an unknown quantity at this point
Making a custom Dashboard with two camera feeds?
I want to make a custom FRC Dashboard in LabView with two camera feeds instead of one. For some reason I cannot find the project template for it in Labview, and the getting started window doesn't have anything pertaining to dashboards at all. Is there a download for the VI template for making FRC dashboards? Or could someone upload the type of dashboard I'm talking about? It is rather frustrating, and I'm fairly sure I did "install everything" in the labview install we got in the KOP.
"Mecanum drivetrains, like every other, have advantages and disadvantages, but some of the disadvantages being discussed here are overstated and/or misinformation." -buchanan
Unread 14-02-2013, 13:01
Re: Making a custom Dashboard with two camera feeds?
Did you also install the LabVIEW update? Full instructions for installing everything you need are here: http://wpilib.screenstepslive.com/s/...w-for-frc-2013
Unread 14-02-2013, 19:17
Thanks, that's probably it. Downloaded from: http://joule.ni.com/nidu/cds/view/p/id/2261
Unread 15-02-2013, 00:07
jertel's Avatar
jertel jertel is offline
FRC #0706 (Arrowhead Robotics)
Team Role: Electrical
jertel is an unknown quantity at this point
Is it possible given the bandwidth constraints to have two camera feeds? Is there any rule that would interfere with having two cameras?
Unread 15-02-2013, 01:59
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
If you keep it at 320x240 and turn down the fps/turn up the compression, it's quite possible.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 15-02-2013, 04:55
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
CodeYeti is an unknown quantity at this point
If you're just looking at having two camera feeds on the dashboard, without doing any processing with the images on the robot, then you shouldn't have to write (draw?) any LabView stuff on the robot to get the cameras to show up. They're just network cameras, assuming you're using an axis camera.
Unread 15-02-2013, 07:31
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
If you only ever need to view a single camera at a time then it is relatively easy to create a toggle button on your joystick/controller that changes what camera LV displays. We did this successfully last year. If your interested I can dig up the project and post it.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 15-02-2013, 08:13
I would be very interested! Is your code for it in Java?
Unread 16-02-2013, 10:33
kylelanman's Avatar
Programming Mentor
AKA: Kyle
I do apologize for taking a while to respond. In short that project is gone forever. The HD in our programming laptop went out so at that time last year we were using a personal laptop for LabView. Only the C++ code was under version control and the laptop has since been formatted.
Essentially what we did was send a Boolean across in our DashboardDataPacket called CameraToggle. Our cameras were on 10.xx.yy.11 and 10.xx.yy.12. CameraToggle can be changed by a button or any way you like in the code. For us, if the shooter was on our alignment camera was shown. If shooter was off then our floor camera was on so we could see to pick up balls.
if CameraToggle was true then we showed .12 if it was false we showed .11. There is a section in the LV panel that determines the IP address that the camera view connects to. We inserted the above logic in between the IP and the camera view. There was one other thing we had to wire up to the camera view regarding the authentication of the second camera. Unfortunately no one remembers the details of it.
Sorry this wasn't as helpful as I originally hoped it would be.
Unread 16-02-2013, 15:53
That's okay, thanks for the insight. We're just going to use two Chrome windows for now, I made a script that opens them at the right URLs for the cameras, and it performs very well.
