Go to Post Just put it in the dryer for a few extra cycles. That should shrink it down nice and small. - notmattlythgoe [more]
Unread 14-02-2013, 17:20
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
Vex 2-Wire Motor 393
Hello all! We are planning on using a Vex 2-Wire Motor 393, but are having difficulty in connecting the motor shaft to a 1/2" bolt. Any suggestions or help? Thanks!
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
Unread 15-02-2013, 01:23
dtengineering's Avatar
AKA: Jason Brett
Re: Vex 2-Wire Motor 393
Use a lathe to drill a 1/8" hole down the middle of the 1/2" bolt.
Place the VEX axle shaft down the hole and JB Weld, or better yet, braze, it in place.
That is assuming you have access to a lathe, of course. If not then maybe braze one of the metal high strength VEX gears onto the end of the 1/2" bolt?
Jason
Unread 15-02-2013, 01:35
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Jason
Better method than glueing a VEX shaft into a round hole: drill a press fit hole for 1/4". Then take the metal VEX shaft coupler, and press fit it into the hole.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-02-2013, 09:52
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
A complicated way that we are doing is drilling a hole large enough for the vex shaft into the end of the bolt. Then using a 1/2 in shaft collar we drilled and threaded holes in the shaft collar so we could connect a vex lock bar to the collar. then we slid the vex shaft into the end of the 1/2 shaft through the lock bar and used mini vex shaft collars to hold the vex shaft to the lock bar.
461 Westside Boiler Invasion
45 Technokats
