Go to Post I know the code works, I wrote it! It must be a hardware problem. - buss [more]
Unread 15-02-2013, 01:31
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
Encoder Feedback in BDC-COMM
We’ve been unable to receive any encoder data using the BDC-COMM utility. We’re currently running BDC-COMM 107 with Jaguar firmware version 107. We hooked up an E4P http://usdigital.com/products/encode...rotary/kit/E4P (E4P-360-250-N-S-D-D-2) encoder to the Jaguar and established communications with it via BDC-COMM. Suspicious of poor disc alignment or bad connections in our circuitry, so we measured the encoder output with an oscilloscope and confirmed a square wave signal coming off of the appropriate lines. Next, testing the connectors off of the encoder lines, we sequentially took things apart to the point where the lines (which we’d confirmed the signal on) were gator-clipped into the pins of the jaguar’s encoder input. To be clear, these are the connections we made.
+5VDC -> ‘+’
Ch A -> ‘A’
Gnd -> ‘-‘
Ch B -> ‘B’
From the software side of things, we’re sure we have communications with the Jaguar (we can read temperature, voltage out, and current out in real-time, and drive motors in these modes), we’ve specified the number of encoder lines (360), and we’ve tried both reference settings (encoder, which should use only the ‘A’ channel, and quadrature encoder, which should use both ‘A’ and ‘B’).
With this setup, we’ve tried both spinning the encoder by hand and running it on a gearbox. In BDC-COMM, the values associated with the encoder output (speed, position) remain firmly at zero.
Any thoughts as to what we might check next?
Unread 15-02-2013, 10:33
cmoon71 cmoon71 is offline
AKA: Chuck Moon
FRC #3015 (Ranger Robots)
cmoon71 is an unknown quantity at this point
Re: Encoder Feedback in BDC-COMM
Have you set the encoder counts/rev? The default value is 0 and unless you set this to a number, you will always read a 0 speed.
Unread 15-02-2013, 12:14
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
You need to set the mode to Speed Mode for the encoder speed to display. Switch back to whichever mode you want to control it in and you should now see the speed reported.
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
