Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Unread 23-01-2003, 15:34
EricEnsor EricEnsor is offline
None #0497 (MRSA)
EricEnsor is an unknown quantity at this point
Send a message via AIM to EricEnsor
Post Tips for Sensor Programming and Testing
Would anyone have any tips for sensor programming and testing? We're trying to find the Optical sensor line tracking. Would anyone know to do this?
Unread 23-01-2003, 16:01
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
The optical sensors are digital (On/Off) devices. Wire them up to Robot Controller and sent the output to the Operator Interface LED
example:
out8 = rc_sw1 'optical sensor 1 wired to switch 1
out9 = rc_sw2 'optical sensor 2 wired to switch 2
Now you can see what the robot is seeing
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 24-01-2003, 07:54
rust710's Avatar
Happy Birthday! rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Line tracking is very simple. I can do it with one sensor and 5 lines of user code added to the default code. I hooked the white wire to rc_sw1(port one on the Digital Inputs) and used this code.
if rc_sw1 = 0 then
PWM1 = 137
PWM2 = 90
else
PWM1 = 90
PWM2 = 137
endif
This is the simplest way I can think of to do line tracking. The only problem is it is slow and it can lose the line with a bump or the sensor not reading right. I would recommend using at least two sensors to follow each side of the line.
Hope this helps.
Unread 24-01-2003, 11:28
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
make sure there is contrast between the floor and the tape (or whatever you're tracking). i've tried a simple program, but it doesn't work because of that reason. i think i've found a floor that works now though .
AIM --> Woloi
Email --> ian@woloschin.com
Testing Autonomous at Competition Yan Wang Programming 9 21-02-2003 19:17
Image Discuss: Team 356: Drive base ramp testing CD47-Bot Robot Showcase 5 14-02-2003 19:44
testing (EOM) archiver 2001 0 24-06-2002 04:08
testing archiver 2001 0 24-06-2002 00:58
testing team222badbrad Chit-Chat 5 15-01-2002 09:49
