Go to Post 7 divisions would be... interesting. - cadandcookies [more]
Unread 15-02-2013, 02:52
Keefe2471's Avatar
Keefe2471 Keefe2471 is offline
FRC #2471 (Team Mean Machine)
Keefe2471 is on a distinguished road
Re: Disk Orientation
Originally Posted by Orion.DeYoe View Post
When you shoot out the discs and then land on the floor, 4/5 times they land upright. Frisbees are airfoils and they want to stay upright.
Was that including contacting the wall? I would think that the wall would increase the randomness of the frisbees orientation by more then that.
Also, have you tried it firing against the nets that surround the field. One strategy I see being imployed by feeder station bots is if they are blocked by an 84 in defense bot (which they will be if that strategy becomes a meta-game). They simply change angle and chuck them as hard as they can at an angle designed to get over such a defense bot. Then they need a robot with intakes and at the far end to suck frisbees in and fire them. Which it sounds like doesn't require orientation at all. So in that case a third robot needs to be brought in to take those frisbees which are landing fairly randomly do to the net having a bit of give. In that case orientation by that bot is key in order to insure range and some accuracy so it could then quickly turn and fire those to its corresponding offense bot on the other end.
Not sure if that made any sense. I am currently suffering from overexposure to coolant fumes
Last edited by Keefe2471 : 15-02-2013 at 02:54. Reason: Spelling/understandableness
Unread 15-02-2013, 02:59
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Unless the wall matches the curvature of the top surface of the frisbee, then I don't see them falling upside down after hitting a wall. The only possible case would be if there is no rotation on the frisbee. The net on the other hand might cause some more variances, but unless you were trying to hit the net, you're not going to hit it.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 15-02-2013, 03:17
Keefe2471's Avatar
Most of the videos that teams have posted have shots hitting the wall with serious force at an angle of at 45 degrees or less from the bottom of the frisbee to the wall if they are shooting from the area around/in front of the pyramid. Will that change how they land? Will a long and herefor more flat shot illustrate what your are hypothesizing better?
This just makes me more excited for week 1 and seeing how the game developes with time. The super complicated stratagem I posted earlier was more of a championships level of depth in an alliance. I think you will see 2 of those three positions filled on most alliances that win early regionals. Or not.
Last edited by Keefe2471 : 15-02-2013 at 03:20. Reason: Actually making a debatable point :)
Unread 15-02-2013, 11:32
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Just adding a tiny bit of info on 706's flipper to up the curiosity factor. Our fully internal disk flipper is completely passive. No sensors, no coding no electricity, no pneumatics and fully effective at flipping upside down bee's and leaving right side up bee's alone.
Pics coming soon.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
