#16
Re: Using Anderson PowerPoles
Either the terminal is upside down, you are using the small section or there is a problem with the crimper. The terminal should insert into the tool in the center port (if you are using the 35 amp contacts) with the contact area up. Can you post a picture of the contact after you crimp?
