Go to Post That box you think you see is only an illusion. - Alan Anderson [more]
Unread 15-02-2013, 08:59
Andrew Lawrence
Posts: n/a
Re: 4 Wheel Drive Too Much Traction
I know this is a little off topic, but is your robot made out of aluminum? It doesn't look like aluminum to me.
Unread 15-02-2013, 09:03
thmeans06 thmeans06 is offline
Drive Coach, IT Support, Mentor
FRC #0066
thmeans06 is an unknown quantity at this point
Find your center of mass and (looks like it is toward the right side in the picture) and shrink your wheelbase by moving either your front or back wheels closer to the center mass.
Unread 15-02-2013, 09:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
That's pretty obviously bent and welded sheet steel. I know we're all about the lightness in FRC, but has it actually reached the point where people can't recognize steel when they see it?
Unread 15-02-2013, 09:37
Andrew Lawrence
Posts: n/a
I recognized it as sheet steel right away, I was just curious because I was talking to someone on 253 earlier and they said they were using aluminum.
Unread 15-02-2013, 09:51
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm curious as to how those pneumatic wheels/hubs are fixed to the output shafts on the CIMs. Care to share the details?
Unread 15-02-2013, 12:50
Racer26 Racer26 is offline
If I had to guess, I'd say those are AM hubs with the 8mm bore /2mm keyway in them, and a snapring just inside them, bolted to the wheel (ie. the snap ring is on the end of the motor shaft, inside the body of the wheel.
Unread 15-02-2013, 12:54
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
The easiest fix is to put tape on your wheels and leave it there so that the tape is what contacts the ground, the won't be able to push anyone but you will be able to turn, we did this a few years ago wrapping our wheels in duct tape at the competition when we realized it was becoming a really big issue
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 15-02-2013, 10:07
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
That without a doubt is steel
2015 GKC Engineering Inspiration
2015 Colorado Winners
