Go to Post I am thoroughly convinced FIRST is a sport. Convince me otherwise. - Bharat Nain [more]
Unread 27-01-2013, 21:51
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Using Anderson PowerPoles
I should have added that for extra added protection we follow the crimp with solder. Yeah it is sort of like suspenders and a belt.
We do this as well. In fact, we solder every connector on the robot, after crimping. It's just too easy to get a bad crimp and thus a loose wire.
2016: Lake Superior WFFA
Unread 28-01-2013, 16:54
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
I personally hate when people go all quick connect happy. Motors make sense, so do things on removable parts of the robot, like an arm with motor(s), switches, sensors, that can be easily removed for repairs, but every circuit seems like overkill.
Unread 14-02-2013, 19:53
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
djdaugherty is on a distinguished road
We started using Anderson PowerPole connectors last year and we love them. We purchased the crimp tool from West Mountain Radio. Does anyone else have the problem of the crimped end getting stuck in the crimper? We need to pry each one out. Any suggestions?
Unread 15-02-2013, 07:35
Either the terminal is upside down, you are using the small section or there is a problem with the crimper. The terminal should insert into the tool in the center port (if you are using the 35 amp contacts) with the contact area up. Can you post a picture of the contact after you crimp?
Unread 15-02-2013, 09:25
Mentor, LRI, MN RPC
We have had the same problem with the 45A contacts, but the PP30's and PP15's seem to work just fine. Most of the time when it happens, we spray a little WD-40 onto the tool and it helps.
Unread 15-02-2013, 22:36
DonRotolo's Avatar
Back to humble
FRC #0832
We also see the same issue.
What appears to be happening is that small 'ears' form on the crimped terminal because of metal getting squeezed into where it shouldn't, making it get a little stuck in the tool.
We keep the terminal cavities lightly greased, this nearly eliminates the problem. Just a little swipe with a q-tip that's greasy is enough.
Unread 16-02-2013, 14:39
Mrs. D.
A dab of white lightning and we are all set! Thank you everyone. Al - we are using the 45A connectors and the last hole on the crimper.
Unread 17-02-2013, 00:16
Dj,
Still it doesn't seem right. Does it seem to you that you have to really hog down on the tool before it releases? It may be misadjusted.
Unread 17-03-2013, 18:44
kyle1997's Avatar
kyle1997 kyle1997 is offline
FRC #4206 (Robo Vikes)
kyle1997 is an unknown quantity at this point
Can anyone give me a link or part number for the West Mountain Radio Crimp Tool? I googled it...but there were way to many diffrent crimpers.
Unread 17-03-2013, 19:03
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
We use them on the all our motors except the CIM. We took a minibot 12 volt power pack and added a double throw switch with a set of connectors. We then use the fixture to test our manipulators without having to wire up the electronics. We can power our compressor and test our pneumatics
Here is a good place to buy them from.
http://www.powerwerx.com
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 17-03-2013, 19:19
Mentor, LRI, MN RPC
http://www.westmountainradio.com/pro...ts_id=PWRcrimp
Unread 17-03-2013, 19:35
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Originally Posted by roystur44 View Post
We use them on the all our motors except the CIM. ...
Why not use them on the CIMs?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 17-03-2013, 19:49
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We don't use them on our drive CIMs either, they are close enough to their speed controllers that we just use the yellow female tabs and the small tab connectors on the speed controllers.
Unread 17-03-2013, 20:08
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
We locate the speed controllers to have the shortest length of wire. No need to add a connector for a drive train motor. If we use the CIM for a manipulator motor we would add in the connector. It makes changing the motors out so much easier year to year.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
