Go to Post Search is amazing. Give it a try. It's 10,000 lines of code that gets lonely if it's not played with often. - Brandon Martus [more]
Unread 15-02-2013, 09:47
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: <R31> Regarding Split numbered bumpers
The blue box reference is correct, numbers can be split with the clear intent that numbers be "unambiguous so that Judges, Referees, Announcers, and other Teams can easily identify competing ROBOTS." This may be difficult for teams with numbers 22, 2222, 11, 1111, etc. I tell teams when asked, "you want to play on Saturday, right? Then you have to be sure you can be identified from the stands."
So... ...to pick a number number at random, suppose I wanted to label a robot 3958. Could I put 39 on the Left and 58 on the rear?
It is going to be really hard/impossible to get a 4 digit number on one side or the other (each only 11" wide including the 8" + the 3" from the edge of the side bumper)
I am not part of the Fairness Cult but this seems like a pretty big deal for 4 digit teams. If a 3 digit team can have an 8" bumper and a 4 digit team needs a wider one, ... ...well... that kinda stinks.
Joe J.
Team #88, TJ2
