Re: <R31> Regarding Split numbered bumpers
I don't see how the rule is ambiguous at all. The rules clearly state you can split numbers as long as when you look at a robot you know it doesn't belong to, say, teams 39 or 58. (Ironically, these teams both exist)
Have you considered something like putting 39- on one side and -58 on the other? Hyphens might make it look less ambiguous. That said, keep in mind you actually have 10.5" of bumper fabric to write your number on an 8" bumper. |
Joe J. |
Don't do the split. We did a split last year over our floor pickup area, and ended up having to make ducttape numbers during inspection to fit them on one side. It won't get past inspection.
The restriction on split numbers was LAST YEAR. This year's rules clearly states that there is no restriction on split numbers, only that your numbers must be clear and unambiguous.
8" of bumper plus the corner space of 3.25" is 11.25 of space. At .5" stroke, with 1" gap between digits, that only takes about 9". And there is a .75 stroke font we created and used last year that also fit nicely on a minimal bumper. It is free to use for any team: http://www.chiefdelphi.com/media/papers/2630 |
Joe,
We have used split numbers for years without too much trouble. Last year the GDC introduced the change thinking it would help in refs doing the real time scoring. So you can do whatever is easiest for your team. With a team number like 3958, refs should not have a hard time figuring it out. The team numbers I pointed out above could be confusing if both teams 22 and 2222 competed in the same event and 2222 split their numbers. The eight inch rule was actually established by calculating the width needed to fit "8888" on a bumper with the corner added. Now if you are like me/us (WildStang) we have a hard enough time coloring inside the lines and getting the team number right side up! |
#7
Ahhhh. Now we know why they tie-dye!
