Go to Post Our rookie drivers generally get their first "real match" experience at the Florida Regional which is usually a week 2 or week 3 event. That is a much easier "practice event" than IRI. - Kit Gerhart [more]
Unread 15-02-2013, 10:18
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
Re: <R31> Regarding Split numbered bumpers
Don't do the split. We did a split last year over our floor pickup area, and ended up having to make ducttape numbers during inspection to fit them on one side. It won't get past inspection.
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
Unread 15-02-2013, 10:25
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
The restriction on split numbers was LAST YEAR. This year's rules clearly states that there is no restriction on split numbers, only that your numbers must be clear and unambiguous.
Academic Student (Forever)
Unread 15-02-2013, 11:00
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
If you have a gap of 16 inches between the split numbers, and your robot is partially obscured by a field element or other robot so that I can't see the other two digits (but can see the gap), then you have ambiguity.
8" of bumper plus the corner space of 3.25" is 11.25 of space. At .5" stroke, with 1" gap between digits, that only takes about 9". And there is a .75 stroke font we created and used last year that also fit nicely on a minimal bumper. It is free to use for any team:
http://www.chiefdelphi.com/media/papers/2630
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 15-02-2013, 11:42
Joe,
We have used split numbers for years without too much trouble. Last year the GDC introduced the change thinking it would help in refs doing the real time scoring. So you can do whatever is easiest for your team. With a team number like 3958, refs should not have a hard time figuring it out. The team numbers I pointed out above could be confusing if both teams 22 and 2222 competed in the same event and 2222 split their numbers. The eight inch rule was actually established by calculating the width needed to fit "8888" on a bumper with the corner added.
Now if you are like me/us (WildStang) we have a hard enough time coloring inside the lines and getting the team number right side up!
Unread 15-02-2013, 11:45
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Joe,
So, when you use split numbers, how does WildStang split them? 1 and 11, or do you chop the middle 1 in half?
2016: Lake Superior WFFA
Unread 15-02-2013, 11:58
Jared Russell's Avatar
Taking a year (mostly) off
Yep, getting "111" right side up definitely sounds like a challenge.
Unread 15-02-2013, 13:12
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Ahhhh. Now we know why they tie-dye!
Hi!
