Go to Post Unfortunately, you cannot always tell when some things are jokes on forums, because we only can rely on text and a limited number of smilies. - artdutra04 [more]
Unread 24-01-2013, 12:45
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
AndyMark Axis M1011/M1013 Cameras
We ordered the M1011 camera from andymark and received the m1013 instead. Did anyone else get the wrong model? The packaging looks similar to the m1011 we have, but the lens on the actual camera is different. Before we open up the box, does anybody know if the m1013 is almost the same as the m1011?
Unread 24-01-2013, 14:35
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: AndyMark Axis M1011/M1013 Cameras
The M1011 was replaced by the M1013. The M1013 has a wider field of view (67 degrees vs 47 degrees) and adjustable focus. With the wider viewing angle, check your distance calculations if you are using the default vision program.
Here is the datasheet that has information on both cameras:
http://www.axis.com/files/datasheet/...en_1211_lo.pdf
Eric
Unread 24-01-2013, 14:53
apples000's Avatar
Well, the m1013 has quite a few changes in terms of image sensors/lens, so we're in a bit of trouble because we have one of each, and we need two of the same. Do you know where we could purchase a M1011? We don't want to order another from AndyMark, because they advertise m1011 and sell m1013!
Unread 24-01-2013, 14:57
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
We just ordered an m1011 off Amazon (for $20 cheaper!). Should be in today, but I havent got my hands on it yet. But check there
Unread 15-02-2013, 10:47
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Bought 2 used Axis M1011 cameras off Ebay for $75 each. Both worked fine.
