Go to Post I'm about to brain myself on a wall in frustration! - pfreivald [more]
Unread 15-02-2013, 15:46
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Gadeer Zbedat is an unknown quantity at this point
which channel does the pressure switch work ?
on which channel in the Crio does the switch work ?!! ( analog breakout) ???
Unread 15-02-2013, 15:48
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
Re: which channel does the pressure switch work ?
Any of the DIO pins on the digital sidecar. You set the channel/pin for the switch when you create the compressor object.
Unread 15-02-2013, 15:50
stuart2054 stuart2054 is offline
Controls Mentor
AKA: Stuart Sebright
FRC #2054 (TECH Vikes)
stuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nicestuart2054 is just really nice
The pressure switch goes to one of the digital inputs on the sidecar. We usually put it to DIO #1 but it doesn;t matter as long as you program it correctly in the cRIO.
Unread 15-02-2013, 15:53
I didn't mean that !! I ment which two cables of the PWM should we configure it to the pressure switch ??
Unread 15-02-2013, 16:04
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Ground (black) and Signal (white) are wired to the pressure switch.
The rest of the PWM goes to the digital sidecar, and it is read as a digital input. (And whatever you use to control the compressor should take an extra number for the switch. Well, at least how that's how the Java library handles it.)
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
